Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Please Guys Hellllllllp!!! Reward!!!!!!
Old 06-30-2008, 06:20 AM
woodz428's Avatar
woodz428 woodz428 is offline
Troll Hunter
Since you failed to mention what engine it is, I will add to the other suggestions. Is your PCV plumbed in?? Do you have good breathers, if not?? I diagnosed an issue with an engine that someone had put after market valve covers on but hadn't knocked out the breather holes when they were installed. The engine leaked profusely and would quit when the pressure built up to a point. You could have too much crankcase pressure, created by a number of things including a poor ring seal.
