please help - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2010, 11:08 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
please help
Ok so Im not good with anything electrical,but not too long ago I tryd to install a kill switch and a tach.Well I spliced a wire into my dist ignition wire then another to the body for a ground.for the tach I pluged the tach light where it goes the hot wire to my volt cluster gauge the light wire to the hot headlight wire and ground to the body.I went to start it and the battery light on my dash came on.I un pluged everything where it connects to the tach and put tape around the wire.well it wouldnt keep a charge.I put on a new battery,new alternator,and a high torque race starter.lightvwent off then back on 15 minutes later,then kill switch wires caught on fire.I took it off and thouht that would solve it,it didnt I charged it today the light onvthe dash came back on and it still wont hold a charge and i keep replacing my battery ground and it keeps getting hot and so does the alt whats going on?please anyv ideas?Im all ears it would help alot thanx
Old 02-13-2010, 09:21 AM
A kill switch should interrupt the power to the distributor not ground it. You have a major short if wires are getting hot. I think you are sending power straight to ground. Wire the switch inline with the power wire to the distributor.
Take some pictures of your wiring and post/link them. Along with the all the ignition and charging system. If you draw up a sketch of what your wired that would be helpful. a + and - on a box for the battery. Keep disconnecting stuff you wired. a test light in line with the wiring at the battery can help diagnose. The brighter the test light the worse your short. Do you have fuses on components? Hate to see your ride turn into a ball of fire. Don't hook up the battery until you can't light a test light inline with one disconnected cable and the battery.
Old 02-13-2010, 09:23 AM
If you were quite a bit closer I may have been able to show up and help..
Old 02-13-2010, 10:18 AM
kleen56's Avatar
To install the kill switch, you splice the two wires coming from the switch between the wire on the distributor. The switch will act as a breaker. By you grounding the wire, you created a major short. You may want to install a fuse in the line as well so it doesn't fry wiring and will just blow the fuse.
Old 02-15-2010, 01:20 AM
two cups of tea
Wiki Edits: 2
well I disconnected everything and put it back the way it was before,and the battery light still comes on and the door ajar sound
Old 02-15-2010, 06:06 AM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
I bet you popped a fuse, (why the Alt. light is on). The alternator exciter wire is generally on the INST fuse. Could be why the buzzer is buzzing too. Check them all with a test light, any fuse that's hot on one side but not the other is blown. There will be one or two that have no juice unless the H/L switch is on, and probably one that has no juice unless it's in the crank position, the one you're looking for will be hot with just the switch on.
Old 02-15-2010, 07:49 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Mods- the OP seems to have posted the same basic question here in Electrical as well as on the Hotrodding Basics forum, HERE.
Suppose you could do a merge?
To CTK- you need to only post your question once in the proper (Electrical, in this case) forum...
