Please help BACK SURGERY is Tuesday - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2012, 04:45 PM
I have my SBC 350 built and in the camaro, When I set the roller rockers to no play on the push rod then go 1/2 turn the motor has no compression both valves are open. I then set them at 1/4 turn and again no compression once again I set them with just no play on the push rod and locked them down the motor runs very well but picking up a lot of chater when i try to tighten them to quiet them it picks up a miss because of no compression what the hell am I doing wrong. Going for major back surgery on Tuesday at 9am wish I could take my baby on a test ride before then but I cant resolve this problem confused can any of you please help me.
Old 07-22-2012, 05:19 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It sounds like the lifter plungers are compressed way past zero lash. If compressed all the way, when they bottom out this lifts the valve off the seat.
Zero lash is best felt for by jiggling the pushrod up and down as opposed to twisting it between the fingers and thumb like many tutorials advise you to do.
By jiggling instead of twisting them you can feel AND hear when zero lash is reached.
Here is a page that may help.
The Following User Says Thank You to cobalt327 For This Useful Post:
evad76 (07-22-2012)
Old 07-22-2012, 06:02 PM
I have seen a few sets of Comp Cams hydraulics that acted more like solids. When adjusted to zero lash they would run and sound OK but it was a hassle. I dont know of another fix other than more lifters.
The Following User Says Thank You to lmsport For This Useful Post:
evad76 (07-22-2012)
Old 07-22-2012, 11:47 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You DO have hydraulic lifters, right? What you describe could be because the lifters are solids and not hydraulics.
Help w/telling one from the other is here.
And good luck w/the Dr.
evad76 (07-23-2012)
Old 07-23-2012, 08:04 PM
Thank You
After getting some good old education the last 24 hours I realized that I do have solid lifters in my motor with what you all posted and my boss (a good old motor head from way back) I came home from work set the valves at 12 thousand fired the motor and finally took my baby for a little ride its strong as hell running at 170deg and shiffting good just wanted to say {THANK YOU ALL} Tomorrow is my back surgery and will be layed up for some time but I can at least look out the window and know I built it with my 2 hands and it runs...
Old 07-23-2012, 08:16 PM
Thanks Colbalt
You were right they are solids
Old 07-23-2012, 10:44 PM
vinniekq2's Avatar
12 thou sound tight? Enjoy the beast
Old 07-24-2012, 04:40 PM
solid lifters
If you still have the cam part # you can download the cam specs which list the correct valve lash settings.
Old 07-24-2012, 04:43 PM
454 Rattler's Avatar
NEVER SATISFIED !!
I hope everything went good today. Get back on your feet as soon as you can and let us know how you're doing.
454 RATTLER
Old 07-25-2012, 10:27 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
One more try!
I have submitted two replies to this thread, and neither have showed up!!
Anyway, here is a short page on setting lash. Be careful until you know what the cam is, I'd consider taking it out to see what the ID markings are on it so you know exactly what you're dealing with. I know this is a lot of work...
Good luck.
Old 07-25-2012, 12:16 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
I hope you got everything right, and I wanted to wish you a speedy recovery from the back surgery. I had back surgery 3.5yrs ago (got hurt on the flight deck of a carrier) i've done well since but i've got my days. good luck and take care of your back!
Arthroscopic Surgery Anyone? Beenaway2long Hotrodders' Lounge 16 08-29-2005 09:57 AM
'RIDES' on TLC Tuesday.......... DENNIS SMILEY Hotrodders' Lounge 5 08-31-2004 09:37 AM
It's PHAT Tuesday!!!!! k2mooch Hotrodders' Lounge 2 02-24-2004 08:46 AM
surgery tomorrow akm Hotrodders' Lounge 21 10-23-2003 03:22 PM
I had surgery Friday tm454 Hotrodders' Lounge 8 06-29-2003 09:07 AM
