Please Help (Binding Carpet Edge w/Vinyl) - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2007, 04:06 PM
If there is anyone out there that has done this before please help, my frustration is at its peak. I have a floor mat that I am binding using a 2" wide piece of vinyl and a 1/2" seam allowance, everything looks great in the straightaways but when it comes to the corners at wrapping my selvage around the edge it just bunches up the corner of my carpet and leaves a hump. Just so you know I am sewing at 1/2" Seam Allowance and then as close to the edge of the carpet as possible to keep the binding laying flat, what else should I be doing.
Thanks,
D
Old 02-25-2007, 06:30 PM
Vini Vidi Vici
What kind of radius are you trying to get around?
You can pull the vinyl taught as you go around the corner, it'll narrow a little but that should get you around without the lumps.
Old 02-26-2007, 09:50 AM
binding
1/2'' is to deep try 1/4'' as for the cor ners it depends if they are square or radiused
Old 02-26-2007, 10:35 AM
Vini Vidi Vici
Also there is a thin binding material that won't bunch.
Old 02-26-2007, 04:38 PM
I guess I was going by the Ron Mangus/Taylor Custom Upholstery book and in there they talk about cutting the 2" strips and using a 1/2" seam allowance, however they never show them making or wrapping the corners. I"ll give the 1/4" a try.
Thanks
Old 02-26-2007, 07:18 PM
Alright I tried the 1/4" and got it wrapped around the corner and to the backside, however the carpet now lies flat except for the corner where it cups up is this just normal and I have to deal with it or what?
Old 02-27-2007, 06:51 AM
binding
When you get approach the corner don't stretch the binding ease it in(push a little) thats what gives the extra binding so it doesn't cup.
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 10:45 AM
Carpet Binding ? Redhot-30 Interior 3 12-04-2005 09:38 AM
Painting in pieces. Can I do it? rrmccabe Body - Exterior 33 11-09-2005 08:37 AM
Masking Door Jams etc. 36ford3window Body - Exterior 9 02-06-2005 09:17 AM
How bad did I get Ripped? (carpet installation) Alexander Interior 13 01-23-2004 08:24 PM
