Please help to diagnose- engine with no oil pressure. Oil pump failed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2006, 05:47 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
Hey folks, merry Christmas-
I'm back in town for a few days and my dad's utility vehicle has been down for several months. Its a 1986 dodge mini van with a 2.2 liter motor, 1 barrel carb and a five speed transmission if you can imagine that! Its a beater, but it saves his nice new cars from hauling lumber and whatnot. Figured I might help him out while I'm in town to get the thing back up and kicking. Here's the problem-
I think it was running fine up until he let it sit for a while. Its not uncommon for this car to sit for months at a time, and its never been an issue in the past. Anyway, this time he starts it up and it runs ok, but develops no oil pressure. He says he hasn't popped the valve cover to check, but the top end sounds loud so he's pretty sure no oil is moving up to the top. Clearly the pump has lost its prime. Why? Can this be solved by replacing the oil pump? I'm willing to do that much-
Thanks in advance-
K
Old 12-26-2006, 07:09 PM
DV8's Avatar
DV8 DV8 is offline
Sloe Lurner
Last journal entry: front boxing plates
Pick up tube
Not real familiar with that engine but could it be the pickup tube??
Old 12-26-2006, 07:16 PM
cabowabo's Avatar
big Q
oil pressure gauge
get oil pressure gauge and get a correct reading then replace the oil pump and screen with new shaft
Old 12-26-2006, 07:25 PM
Jmark's Avatar
If may have lost it's prime and possibly the filter is now empty too. A quick suggestion. Pull the oil filter and fill it up and spin it back on. It may drain back down and re-prime the pump. Ck the oil level one last time then try to fire it tomorrow morning and see what happens.
Old 12-26-2006, 10:25 PM
Wiki Edits: 3
thanks for the suggestions. I think he tried to re-prime the pump before and had some success but it has since lost its prime again. I guess I was looking for a go-ahead for the replacement of the pump. Just trying to make sure that its not something else entirely. I guess I could get a manual gauge and check the pressure, but I think its pretty clear that its not developing any oil pressure with the noisy top end.
K
which oil pump for a 406? high volume or high pressure? 406 ss monte Engine 23 09-10-2006 07:48 PM
pontiac 400 low oil pressure, engine noise Blob Engine 3 08-12-2006 09:11 PM
new engine, oil pressure probs montea Engine 35 06-02-2006 12:37 PM
No Oil Pressure!! MartyMart9@aol.com Engine 43 04-26-2005 06:37 AM
Oil pressure loss SB Chevy Finmike Engine 30 06-12-2004 10:27 AM
