Please Help!!! Headlight Issue 1981 Camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2008, 01:33 PM
i have a 1981 camaro and my headlight have been working but stopped this morning? i dont know why but they dont turn on. all the other lights work so i thought it was the bulbs until i clicked the highbeam button and they flashed. they flash everytime i hit the highbeam button. can someone tell me what is goin on?
Old 02-22-2008, 01:35 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
The regular head lights are wired through the high beam switch....its possible one side of your switch has gone bad or you could have a bad or loose connection on that switch.
Old 02-22-2008, 01:38 PM
oooo thank you. do u know how i can get to the switch? its liek in the floor.
Old 02-22-2008, 01:41 PM
Lost in the 60's
Wiki Edits: 4
Pull up the carpet or mat...The switch should be fastened down with two hex head screws......there is a disconnect plug in the wire just a few inches away. The disconnect plug may be full of dirt and moisture etc. That may be your problem. Dirt gets in the switches too and messes them up. They do not cost all that much and you can get one at most any parts store.
Old 02-22-2008, 01:45 PM
thanks man. you just made my weekend way better
Old 02-22-2008, 01:49 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
Also check your ground's,They can cause crazy things to happen.
Old 02-22-2008, 02:00 PM
T-bucket23's Avatar
Wiki Edits: 26
You may also want to check the headlight switch itself. Usually the flash to pass is on a seperate circuit feed so the headlights dont need to be on to use it. It is a common failure and a fairly easy replacement.
Old 02-23-2008, 10:14 AM
If you just turn them on high, do they work, or is it a flash to pass feature (does an '81 have flash to pass?) you are using?
--If they work when you switch to high beam with the floor button or turnstalk switch, then you just have the low beam elements burned out in the headlights. They probably went out one at a time and you did not notice.
-- If they only work on high beam in flash to pass mode, then its probably the headlight switch.
Bruce
Camaro projects for sale... Zartan General Rodding Tech 30 12-12-2008 11:01 AM
1981 camaro 81blownz28 Engine 5 08-23-2004 06:51 AM
78 camaro to t top 87 monte carlo help isleofwight Engine 3 06-28-2004 09:29 PM
Camaro w/383 questions mouse316 Engine 5 05-17-2004 12:32 PM
Wiring Headlight Switch horvath Electrical 7 05-10-2003 07:36 AM
