Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - please help id this 10 bolt posi
Old 03-11-2011, 03:06 AM
ericnova72's Avatar
ericnova72 ericnova72 is online now
More for Less Racer
Just having both axles turning in the same direction does not gaurantee a posi, a burnt up open differential that has friction welded the spider gears to the pin will behave the same way. Best to remove the cover and see exactly what you have.
Widtn measurement needs to be from where the wheel bolts on to get the true width. Nobody lists them by backside of the drum measurements.
