please help id this 10 bolt posi
I have a rear end that was in my grandfather's shop after he passed.Its a 10 bolt looks to be an 8.5 &it is a posi.The only codes I can find are one that says gm 49 another that says 12515002 &one more that has what looks like a o with a horizontal line in it thene 154 and another o with the horizontal line like oe 154 o. PLEASE help Ive looked&looked&can't seem to find no info.
Only code that will mean anything will be stamped into the forward side of an axle tube. Casting #'s won't ID it. a picture would make this real easy.
There is an ID chart at www.novaresource.com for ID'ing the different 10-bolts. Click on "site map", then on "axle codes" and it will take you to the ID page. |
Let me see if this works.
Ok it'll take me a bit to get all of these piz uploaded can't find any other codes me& 2 othee guys looked. Also if it helps from the back of the drums one to another meaure about 58 inches.
Ok I can get some more pix in the morning.I know its a posi,I sat it up on aome blocks&both trums spin the same way.How should I measure it?I just dis from inner hib to hub it was 58 inches.It looks pretty much identical to my monte carlo rear.I took some degreasser&wd40&a wire brush to it&can't find anymore codes
Thanks for the help.
Just having both axles turning in the same direction does not gaurantee a posi, a burnt up open differential that has friction welded the spider gears to the pin will behave the same way. Best to remove the cover and see exactly what you have.
Widtn measurement needs to be from where the wheel bolts on to get the true width. Nobody lists them by backside of the drum measurements. |
I found the code,went&really hit it hard with a wire brush&anyhow looks like 4yp g4142 I can't seem to find any info on it.Any ideas?
| 12-Bolt Posi | MI2600 | Transmission - Rearend | 2 | 07-04-2008 03:22 PM |
| 12 bolt posi 9.375 | hotrodder65 | Transmission - Rearend | 2 | 05-08-2007 04:58 PM |
| 12 bolt posi | CHEVELLE12345 | Introduce Yourself | 1 | 06-29-2004 05:56 PM |
| What posi in my 12 bolt. | Ed ke6bnl | Transmission - Rearend | 1 | 04-23-2003 06:21 PM |
| 10 bolt posi | 67rscamaro | Transmission - Rearend | 16 | 02-27-2003 07:22 PM |
