First check the Hotrodders Knowledge Base. Here's the relevant category: Transmission-Rearend Technical Data.
HomemadeTools.net -- Thousands of Homemade Tools |
These sites may help; http://novaresource.org/axle.htm
http://truckparts-specialists.com/ca...ture-guide.htm |
This guess will probably end up way out in left field but here is my guess:
the 10 bolt cover could be an 8.2 or 8.5 Chevy, or it might be a GM large car rear end. It is not a BOP 8.2 axle since there was no 4.11 ratio that I know of (3.90 then 4.33). While none of the charts support it, it looks like the J211 is a date. The J would be October, 21 would be the 21st, and the 1 probably is for 1971 (or maybe 1981, 1991?) If it is a BOP big car, it would not be 1961 because they used a carrier like the Ford 9" until 1964. The BOP big car had a 10 bolt cover and a 12 bolt ring gear. So what is stamped on the ring gear, and what is the distance between backing plates? |
| vette differential question | vettetxx | Transmission - Rearend | 2 | 03-11-2006 05:28 PM |
| Differential noise after warming up? | frankenvette | Transmission - Rearend | 3 | 07-08-2004 07:05 PM |
| Differential reliability. | M&M CUSTOM | Transmission - Rearend | 0 | 10-26-2003 01:47 AM |
| Corvette differential trouble | HotRodMan | Transmission - Rearend | 0 | 02-09-2003 05:19 PM |
| Differential Identification | Ed Orbea | Transmission - Rearend | 1 | 10-31-2001 03:32 AM |
