-   -   Please help ID my GM 12 bolt (http://www.hotrodders.com/forum/please-help-id-my-gm-12-bolt-210213.html)
akorcovelos 12-12-2011 05:42 PM
Been searching around the net, mostly here, and can't find much to help me ID this rear end. It came out of my '72 Chevelle, but I have no idea if its original.
The numbers I can find are all on the pumpkin, nothing on the tubes. I found the following (pics below):
GM53
3969278N
12345
67890
H299
00N1 or I
The housing is 55" or 54 1/4" long from dust shield to dust shield.
The cover is 10.5" wide.
http://i224.photobucket.com/albums/d...x/IMG_0215.jpg
http://i224.photobucket.com/albums/d...x/IMG_0214.jpg
http://i224.photobucket.com/albums/d...x/IMG_0213.jpg
http://i224.photobucket.com/albums/d...x/IMG_0212.jpg
http://i224.photobucket.com/albums/d...x/IMG_0211.jpg
http://i224.photobucket.com/albums/d...x/IMG_0210.jpg
http://i224.photobucket.com/albums/d...x/IMG_0208.jpg
http://i224.photobucket.com/albums/d...x/IMG_0209.jpg
http://i224.photobucket.com/albums/d...x/IMG_0207.jpg
http://i224.photobucket.com/albums/d...x/IMG_0206.jpg
http://i224.photobucket.com/albums/d...x/IMG_0202.jpg
http://i224.photobucket.com/albums/d...x/IMG_0201.jpg
http://i224.photobucket.com/albums/d...x/IMG_0199.jpg
The car was wrecked and I'm in the process of fixing it. The drivers axle was bent at the flange and I need to replace it. I'm taking it to Dick Strang in Waukegan, IL for a refurbish, new axle, control arm bushings, wheel bearings, c-clip eliminators, and a disc brake conversion, so I would like to go there knowing what I have and what I need to source for parts.
Thanks, this site has been a tremendous help since I got this car! :thumbup:
cobalt327 12-12-2011 06:16 PM
A quick search shows 3969278N to be a '70-'72 Chevelle 12 bolt. The date code H299 is August 29 of '69, so this would have likely been used in a '70.
There should also be some stamped (not cast like on the center section) numbers on the axle tube.
akorcovelos 12-12-2011 06:33 PM
Thanks Cobalt! I'll go have another look on the tubes after I scarf some dinner down, BRB! :)
akorcovelos 12-12-2011 07:23 PM
ok, I found some stamped numbers on the pass side tube front side. Best I can tell it reads: C6H 0909B
I'll let the pics do the talking, maybe I'm reading it wrong.
http://i224.photobucket.com/albums/d...x/IMG_0219.jpg
http://i224.photobucket.com/albums/d...x/IMG_0218.jpg
http://i224.photobucket.com/albums/d...x/IMG_0216.jpg
If there is anything under that cover that will answer some questions let me know what to look for and I'll go pull it off and take a couple pics.
Thanks for the help!
cobalt327 12-12-2011 10:09 PM
You were close- it's actually "CCH". Means it was originally a 2.73:1 posi. The "0909" is September 9, which corresponds to the August 29 casting date.
The "B" is Buffalo, NY assembly plant.
akorcovelos 12-13-2011 07:05 AM
Ok, so originally it had a 2 series carrier? If I pull the cover can I id the gear set and carrier that's in there now? What should I look for when snapping pics?
SSedan64 12-13-2011 07:35 AM
The Ring Gear will have the Pinion & Ring gear teeth numbers stamped, Part #'s & Date.
Example 41-11 = 3.73, 41-10 = 4.10, 41-15 = 2.73
Carrier will have:
Casting #-----Series----------Gears-------
ED32088------- 2--------- 2.73:1 & down
30140PM1------ 3-------- 3.08:1 to 3.73:1
EDB30174------ 4--------- 3.90:1 & up
akorcovelos 12-13-2011 07:40 AM
Great info, thanks! I'll pull it apart tonight after work and update the thread.
akorcovelos 12-13-2011 04:51 PM
ok, pulled the diff cover and I'm a little confused.
it looks like the number on the carrier is ED -32088 which would be a 2 series, but the number on the ring gear is 2 GM 3862525 11 41 3 67 which is a 3.73:1?
http://i224.photobucket.com/albums/d...x/IMG_0228.jpg
http://i224.photobucket.com/albums/d...x/IMG_0221.jpg
SSedan64 12-13-2011 05:08 PM
Someone used a Ring Gear spacer which allows you to use 3-Series Gears in a 2-Series Carrier. :mwink: Not the strongest method but, they work.
Looks like March, 1967 GM gears.
cobalt327 12-13-2011 05:13 PM
And you're correct on them being 3.73's.
akorcovelos 12-13-2011 05:19 PM
hmm, how much power is this setup good to?
