please help....keep frying ignition mods - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-22-2012, 03:22 PM
T-bucket23's Avatar
Wiki Edits: 26
Originally Posted by spiffy61
Ok, finally got a new module in and took a bunch of readings with a quality FLUKE meter. These were taken at the distributor. This is an HEI dist in a 350sb 1981 chevy C10.
12.0 V dc not running.
9.5 V dc starting.
13.6 V dc idling.
14.3 V dc @ 50 mph.
.5 VAC @ 50 mph
4KHz @ 50 mph.
1.6 Amps dc @ idle
2.6 Amps dc @ 50 mph
The alternator has an internal regulator. The only things i found by the fuse box where the horn relay and a stupid looking thing which i found out was a seat belt buzzer (which I put in the circular file)!
4khz @ 50 mph. Please explain where you got this reading.
Chet
  #17 (permalink)
Old 02-22-2012, 08:01 PM
I got that reading when I was checking the DC and AC volts. There is a Hz selection in between the other two on the meter. I assume its just the RF thats generated. How does the other readings look?
  #18 (permalink)
Old 02-26-2012, 02:24 PM
Just wondering if short spark plugs could take out the module prematurely? I have to use short ones becuz of the headers........
  #19 (permalink)
Old 02-26-2012, 02:29 PM
T-bucket23's Avatar
Wiki Edits: 26
There should not be any A/C voltage on the power lines. Where did you take this reading.
if you took it at the distributor it may just be a little feedback.
if you really do have A/C leakage from the alternator it can hurt electronics and could be the source of your issue
Chet
  #20 (permalink)
Old 02-26-2012, 02:31 PM
T-bucket23's Avatar
Wiki Edits: 26
No, they are on the secondary side of the system and should have no effect.
Is the feed for your distributor anywhere near a plug wire?
Chet
  #21 (permalink)
Old 03-11-2012, 01:13 PM
johnnyg's Avatar
hold my beer and watch this!
I had an 86 GMC that fried a couple of modules, when I replaced the pick-up coil and the module it fixed the problem.
Frying pan fix dinger Off-Topic 33 01-31-2007 02:47 AM
What happened to Ignition Man? - The good and bad of Ignition part brands Francis Electrical 4 04-25-2006 10:45 PM
Frying a GEL battery al37ford Electrical 17 08-08-2005 07:59 PM
frying points 6 pack Electrical 2 10-23-2003 08:32 PM
Alternator frying Adrenaline_Fiend Electrical 6 04-15-2003 09:19 PM
