please help with LT1 wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2010, 01:13 PM
i just biught a 1994 LT1 engine from a buick road master i need wiring harness and ecu i found one for $200 from junck yard it out of 1995 caprice cop car 94 is OBD1 i checked acouple chevy dealerships and 3 siad it would work and 2 siad it would not that the 95 is OBD 2 can any one help please and thankyou
Old 07-20-2010, 06:46 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Check the diagnostic connector on the harness donor car.That will tell you if it is obd 1 or 2. I wouldnt think that would matter as obd 2 is only a diagnostic protocal designed to standardize access of diagnostic info . As long as all the sensors are there and all the plugs plug in it will probably work fine.
Old 07-20-2010, 10:36 PM
DOCTOR DC's Avatar
NUCKINFUTS MOTORSPORTS
obd1 works with a PROM and is not compatable with obd2
Old 07-21-2010, 10:55 AM
LATECH's Avatar
prom vs. eeprom
It will work as long as the plug ins match up to the sensors on the engine. Also the OBD 2 system has an EEPROM which stands for Electronically Erasable Program Only Memory which is better than changing the PROM as you dont even need to pull the computer out to do so.OBD 2 is nice because of the EEPROM you can custom tune all the parameters ( If you have the pass through device and the software) the only difference may be the MAF and that could be as simple as plugging in the obd 2 device. I tried to check part numbers but couldnt access them. However 94 -96 airflow sensor looks the same as far as plugging it in and location/installation. I would perform this swap fearlessly as I believe it will work just fine
Old 07-21-2010, 11:13 AM
LATECH's Avatar
The cop car PCM would be kool. It is probably flashed with a good performance tune and probably doesnt have a speed limiter in place. plug and play.
Old 07-27-2010, 06:37 AM
rachet ralph's Avatar
http://shbox.com/1/schematics_wiring.html heres a site for camaro LT1 systems may help you out ! also 1995 was a odd ball year for OBD systems really was'nt a OBD I or a OBD II system an there opti spark I an opti spark II systems with the LT 1 motors
Electrical Wiring kristkustoms General Rodding Tech 16 12-27-2010 11:00 AM
LT1 EFI wiring smoke'studebaker Electrical 6 01-04-2006 08:14 PM
LT1 Conversion Wiring Harness Markgoodman5 Electrical 3 08-17-2004 04:48 PM
LT1 Wiring Harness JimmyL Electrical 1 10-15-2003 04:47 AM
Wiring 1994 LT1 Cool 32 Electrical 1 10-15-2002 11:33 PM
