Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - please help me diagnostic this problem
Old 09-21-2012, 09:18 PM
Augusto's Avatar
Augusto Augusto is offline
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
Originally Posted by cobalt327 View Post
Having inadequate valve spring pressure can cause this. They could be allowing the lifters to pump up.
Be sure to check the lifter preload and geometry. Being that the valve train is non adjustable, the push rod length is critical.
Changes to the following will effect the p-rod length requirement:
Camshaft base circle diameter
Pushrod length due to wear or replacement
Milling heads/block
Different thickness head gaskets
Valve seat height changes from seat replacement or from valve seat grinding/cutting done during valve jobs
Grinding the tip of the valve stem when doing a valve job or different length valves
Lifter pushrod seat height due to different manufacturer
Change in rocker arm type or design, or ratio
springs..?? hmm maybe
now, since I live in a place where it's very hard to get parts for this engine, it really lures me the idea of converting the valvetrain to adjustable, I have a 250 I6 chevy engine that could donate the rockers, I understand that both chevy and ford use the same 1.6 ratio rockers, am I correct?
seems to me like installing some studs in place of the bolts will let me adjust the valvetrain, don't know if the head has push rod alignment guides.
any ideas?
