Please help me pick a cam, intake, and carb- 383 Stroker - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-14-2013, 09:37 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by vinniekq2 View Post
lets say your heads flow 280 ish?
110635-10 NA 290 290 237 237 .560 .560 110 106 Hyd. Hyd. 1,2
2400-6400 Rough idle, Street/Strip, strong mid range. 10.0:1 CR, 2500+ stall.
a cam like this would use most of the heads potential
The engine would make power to 6k plus
torque converter would work great as is. 3.73 gears ,,,? I dont know,that depends on what the car is used for? for the drags it would be fine,for x country travel with out over drive not great.
The 750 double pumper is a minimum.
Myself,I would use a bigger solid cam
vic junior intake and
850 CFM Holley double pumper,,,
this car needs a big exhaust system
Using your Howard's juice roller makes sense . I used AFR195 flow figures, capped at 279/181, bolted the cam in at 6.5, 50.5, 46.5, 10.5, 1 3/4" long-tube headers, X or H pipe before the mufflers, RPM intake, 750 carb.
RPM...HP...TQ
2000...147...385
2500...188...395
3000...240...421
3500...308...462
4000...376...493
4500...436...509
5000...487...512
5500...516...493
6000...530...464
6500...508...410
Peak volumetric efficiency 97.8% @5000
Peak BMEP 201.6 lbs @5000
This is real good cylinder pressure, so tighten up the squish (0.035" to 0.045") for pump gas.
Hydraulic roller lifters are quite heavy and will tend to loft off the cam lobe at crankshaft speeds over 6000 rpm's, so this particular grind works out really well, showing max hp right at 6000. On the DynoSim graph, it heads downhill at 6100 like someone clicked off a switch.
The Following User Says Thank You to techinspector1 For This Useful Post:
Sixshooter45 (05-14-2013)
  #17 (permalink)
Old 05-14-2013, 09:47 PM
Sixshooter45's Avatar
RPM...TQ...HP
2000...147...385
2500...188...395
3000...240...421
3500...308...462
4000...376...493
4500...436...509
5000...487...512
5500...516...493
6000...530...464
6500...508...410
I like the look of that. And would the manifold you are speaking of be the RPM performer, or the RPM air gap?
Again, I really appreciate all y'all's advice. It helps more than you know.
  #18 (permalink)
Old 05-14-2013, 09:53 PM
vinniekq2's Avatar
WOW! look at that torque at 3k?slightly more HP than torque. If that doesn't melt tires and drive well?????
Thanks Richard,,,
  #19 (permalink)
Old 05-14-2013, 09:56 PM
Wiki Edits: 326
I don't put much stock in air gap intake manifolds. Just seems like more snake oil to me, plus I want the motor to come up to operating temp as fast as it can.
  #20 (permalink)
Old 05-14-2013, 09:59 PM
Wiki Edits: 326
Thanks Richard,,,
OOps, sorry, got the hp and tq mislabeled. Should read RPM/HP/TQ left to right. I went back and fixed it.
  #21 (permalink)
Old 05-14-2013, 10:02 PM
Just what I needed to know. So this cam, RPM performer, and a 750 double pumper sounds like a great street combo to me. And I can imagine it would be much more street friendly than the current cam setup by far.
I also noticed pretty much everyone recommending a Holley carb to me. Just curious the reasoning everyone recommends these over a Edelbrock?
  #22 (permalink)
Old 05-14-2013, 10:12 PM
vinniekq2's Avatar
If you buy a carb from the carb shop,Pat will have the carb almost perfect out of the box.Or other reputable carb shop. The double pumper is a great performance carb that is easy to work on.Terrible mileage though.The quadrajet is great too,but maybe a little small,and more difficult to tune
  #23 (permalink)
Old 05-14-2013, 10:15 PM
Banned
Can you simulate that with a cam with maybe about 6-8 degrees less duration on the intake? I think you'll find the power in your driving range goes up substantially, few people buzz a sbc above 5000 rpm under normal circumstances on the street. With 4.56 gears that power band looks more attractive but 3.73 gears are not that steep.
On a car that sees regular track duty that would be a great combo, but I don't see it being useful on the street. I've built a few high winding engines and they're more of a pain in the *** than anything after the first few months.
  #24 (permalink)
Old 05-14-2013, 10:28 PM
Wiki Edits: 326
A Holley will make a little more horsepressure than an Edelbrock, so the racers will most always recommend a Holley. Personally, I would recommend a Rochester Quadrajet mounted on an RPM intake, Edelbrock stock number 7104. I would get the Q-Jet from Cliff Ruggles and have him set it up for me according to my recipe of parts and intended purpose of the motor. It is said that his setups are only a hair away from responding like EFI.
http://www.cliffshighperformance.com/
Q-Jets came in, I believe, 750 and 800 CFM. Either would work. Use caution when putting the rest of your fuel system together. Edelbrock, Carter and Rochester will tolerate only about 5 psi fuel pressure at the bowl before the pressure unloads the needle from the seat and allows the pump to blow raw fuel into the intake manifold and create a tuning nightmare for you. Holleys will tolerate slightly more, about 6 psi maximum. You'll want to use large diameter piping or tubing from the tank to the carb, building a HIGH VOLUME system, but not a high pressure system. Cam-driven mechanical fuel pumps do not take lightly to being collared with a fuel pressure regulator because of their inherent chug-chug design (pressure, no-pressure, pressure, no-pressure). If you plan to use a mechanical pump, then do some research and find one that will limit output to 6 psi for a Holley or 5 psi for any of the others. Fuel pressure regulators work great on electric fuel pumps because of the steady pressure produced by the pump. I like using a return line system instead of dead-heading the fuel into a regulator. You can tee off right at the rear-mounted pump and run a line back to the tank pretty easily.
Just rifling through my brain......
As far as ignition timing, the converter will have the motor revs past the point where you would normally have all the advance in the motor anyway (about 2800 r's), so I see no sense in trying to set up a curve when the motor is just gonna blow right by it. Might just as well lock out the timing at max, depending on the design of the combustion chambers. Tight little bathtub chambers might work really well with a total of 34 degrees, while less efficient chambers might make more power with a little more advance, like 36.
Whatever you do, nail down the exact point of piston top dead center with the mark on the inertia ring of your damper. Most guys miss this.....
http://www.crankshaftcoalition.com/w...op_dead_center
Most guys also miss the fuel pressure......and the squish.......
  #25 (permalink)
Old 05-14-2013, 11:06 PM
Great info, many thanks! I don't know a thing about q-jets but I will definitely take a look at them.
  #26 (permalink)
Old 05-14-2013, 11:29 PM
Wiki Edits: 326
I agree with you, it's just like everything else that gets done to the max. It gets old in just a little while and you wish you had built a more tractable motor.
What I consider a really good street motor is one that produces at least 400 ft/lbs of torque at 2000 rpm's. So let's leave everything else the same as above and just change out the cam to a more sedate grind that will achieve the torque figure that I like. We'll use another Howards juice roller, but with less duration, part number 111145-10......
http://www.howardscams.com/component...h/3/2?Itemid=0
We'll stab the cam in 4 degrees retarded on these numbers....IO (-0.5), IC (39.5), EO (42.5), EC (2.5)
The OP likes a little rump-rump and this cam should rumble a little.....
RPM...HP...TQ
2000...164...430
2500...208...438
3000...267...467
3500...330...496
4000...389...511
4500...435...508
5000...476...500
5500...490...467
6000...476...417
Max volumetric efficiency 95.0% @5000
Max BMEP 201.5 lbs @4000
This cam produces in excess of 450 ft/lbs of torque from 2700 rpm's to 5700 rpm's!!!!!!
  #27 (permalink)
Old 05-15-2013, 09:38 AM
Banned
RPM...HP...TQ
2000...164...430
2500...208...438
3000...267...467
3500...330...496
4000...389...511
4500...435...508
5000...476...500
5500...490...467
6000...476...417
What rocker ratio did you use on that test? If that's 1.5 ratio then that's really good for a moderate amount of lift, I would have expected to need more lift on heads that big, a 1.6 ratio or better. Less lift means a cheaper valvetrain, more durable, and less problems. The torque peak dropped to right about where I would want it for that stall and gears and the HP peak is right where you need it for a 6,000 RPM redline.
That cam makes a VERY usable power band for stop light racing, should also be easier on parts and provide better economy.
  #28 (permalink)
Old 05-15-2013, 11:05 AM
Both of those cams look good. I'm considering going with the first one, incase I decide to upgrade to some steeper gears in the future. And it still looks like it would have plenty of torque for cruising around on the street with this 383 the way I am setup now, right? I have just about 100% ruled out running the big solid cam that is in it now, I think it would just be way too much for my use.
  #29 (permalink)
Old 05-15-2013, 12:35 PM
Banned
Unless you plan on cruising around at 5,000+ rpm on the street, OR you're going to spend a lot of time on the track, I can't find a single reason to no use the smaller one. What do you mean by steeper gears? 6.14?
The bigger cam has less power until about 4500 rpm, and at 3,000 rpm (which is where you'll be at most of the time with those 3.73 gears) you give up 50ftlb! 50ftlb is HUGE.
You can get whatever cam you like, but realize that bigger cams will actually make you SLOWER on the street.
On the track where you shift at 6,000+ RPM its an entirely different scenario.
Take it from someone who has BTDT, you want the power where you drive, not off in some space on your tach that the needle will never see.
The Following User Says Thank You to ap72 For This Useful Post:
Sixshooter45 (05-15-2013)
  #30 (permalink)
Old 05-15-2013, 03:14 PM
Wiki Edits: 326
That was at 1.5:1, I usually don't do higher rocker ratios unless there is some specific reason to try them. Every time they have shown only 10-12 hp difference and that's not enough for me to put up with more cam-tappet interface pressure and more possibility of fraggin' the whole mess.
383 stroker - intake oil leak - HELP! transamgta383 Engine 16 08-16-2011 12:52 PM
carb for my 383 stroker casadoctor Engine 11 04-06-2010 11:34 AM
Too much carb on 383 stroker ? y2k600f4 Engine 6 09-07-2009 09:51 PM
carb for my 383 stroker 7fastelc0 Engine 3 09-20-2002 11:22 AM
