Please help me pick a cam, intake, and carb- 383 Stroker - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 05-15-2013, 06:57 PM
Banned
TI you put too much effort into your posts, if I didn't know any better I'd think you're getting paid for them! I'm sure you've done a hell of a lot of good for a lot of board members.
The Following 3 Users Say Thank You to ap72 For This Useful Post:
AutoGear (05-16-2013), Sixshooter45 (05-15-2013), vinniekq2 (05-15-2013)
  #47 (permalink)
Old 05-15-2013, 06:58 PM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by Sixshooter45 View Post
Great, thank you very much! I think I got confused and thought I should be looking for something other than the Air-Gap manifold. In that case, I can just go with one of the kits that includes the manifold, carbs, linkage etc all in one.
The "high-rise" part of it is where the value is. I wouldn't give you 2 cents for the "air-gap" part of it.
  #48 (permalink)
Old 05-15-2013, 07:03 PM
Wiki Edits: 326
Well, I'm retired and every once in a while, I have the time that's required to do it properly. This has been a very good thread and I thank you for your kind words.
It makes me feel good to be able to pass on valid, useable information to those who might not know where to look for it.
The Following 2 Users Say Thank You to techinspector1 For This Useful Post:
  #49 (permalink)
Old 05-15-2013, 07:04 PM
Sixshooter45's Avatar
I can vouch for that! Techinspector and you other gentlemen have essentially built my engine for me during this thread. A huge thank you to everybody who has contributed and put up with my beginner questions.
  #50 (permalink)
Old 05-15-2013, 07:05 PM
Now I got ya!
  #51 (permalink)
Old 05-15-2013, 09:23 PM
Also, should this combo be OK on pump gas? Or would I need to get the CR down a little? 90 octane is the normal "Premium" in my area, although I'm always on the lookout for better gas. Elevation is 3200'.
  #52 (permalink)
Old 05-15-2013, 09:58 PM
Wiki Edits: 326
If you could drop the SCR half a point to 10.0:1, how would you do it?
If you left it at 10.5:1 and it knocked on bad fuel, would you add a water/alcohol injection unit to stop detonation?
  #53 (permalink)
Old 05-15-2013, 09:59 PM
vinniekq2's Avatar
make sure you do some math before you buy the parts:
The dyno sim difference between the cam I chose and the cam AP72 chose made different amounts of power at different RPMs,,,but,,,
SAME COSTS,,,
you decide how the engine should perform and when it should do it,,,
with the bigger cam and 3k TC,how long do you think the more powerful engine will take to rev past 4k?You will need a rev limiter,,,
the other combo with 2 carbs,,,needs 2 carbs and a more expensive manifold.
You can also consider a bigger cam than I said or a smaller cam than what AP72 said. either way 500 ish HP is in your future.
It will be a lot of fun to drive
The Following User Says Thank You to vinniekq2 For This Useful Post:
  #54 (permalink)
Old 05-15-2013, 10:23 PM
Without changing heads or pistons, could I run a thicker gasket??
  #55 (permalink)
Old 05-15-2013, 10:42 PM
vinniekq2's Avatar
squish
no, a thicker gasket would be a terrible idea. Follow Techs advice about decking the block and we can play around with cam timing to deal with the staic CR ,,,a little bit.( a bigger cam can tame CR thats a little too high)
  #56 (permalink)
Old 05-16-2013, 01:01 AM
Wiki Edits: 326
I really need to know the answers to the questions I asked you in post #4. All of what we have done has been fun, but it is not necessarily carved in stone. The very first thing I need to know is the actual static compression ratio and to figure it for myself, I need the info asked for. If it is indeed 10.5:1 and all you have is 90 octane fuel, we may need to use a little hotter cam timing, closing the intake valve later and relieving some of the cylinder pressure to prevent detonation on pump gas.
  #57 (permalink)
Old 05-16-2013, 08:13 AM
10-4. I'll get that info ASAP!
  #58 (permalink)
Old 05-16-2013, 09:39 PM
Ok, so a little update. I went over to my brothers shop this afternoon and we started to pull apart the engine and clean some stuff up. Come to find out, some of the info I got from the shop that built the engine was wrong. The heads are PC3002 which in my quick search shows a Procomp 190cc/64cc. Doesn't look like they are too highly thought of.
The cam was not what I was told either. It's a solid Isky 547-B #201549. Which evidently is a oval track cam. But it's obviously not what I'm looking for. Roller rockers are blue in color with nothing stamped on them whatsoever.
All I could see of the pistons from the underside of the engine read SRP 40. H beam rods read 8551 S.
Haven't yet gathered any more info to figure the compression ratio as Techinspector has requested. So strictly parts wise, any idea what I'm working with here?
  #59 (permalink)
Old 05-16-2013, 10:00 PM
Banned
That cam is a little too big for your application, and the heads are okay provided they have been checked for machine work and have the bowls and guides cleaned up. You're not sitting as bad as you may think, still need a cam and you probably need some sort of head work.
  #60 (permalink)
Old 05-16-2013, 10:44 PM
Well that's good to hear. I was worried I had some junk heads after seeing a few people talk about them on the web. Do you think I would still be able to utilize a cam such as the 111145-10 that you initially suggested even though the heads are not what we originally thought they were?
383 stroker - intake oil leak - HELP! transamgta383 Engine 16 08-16-2011 12:52 PM
carb for my 383 stroker casadoctor Engine 11 04-06-2010 11:34 AM
Too much carb on 383 stroker ? y2k600f4 Engine 6 09-07-2009 09:51 PM
carb for my 383 stroker 7fastelc0 Engine 3 09-20-2002 11:22 AM
