Please help me pick a cam, intake, and carb- 383 Stroker - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 05-22-2013, 09:17 PM
Sixshooter45's Avatar
Originally Posted by ap72 View Post
If properly built 11:1 will be done on 91 octane, but I wouldn't trust a carb on it, they fall out of tune too easily.
You can run those pistons with no problem or just knock a hair off them if you really want 10.5:1. This isn't rocket science.
People sure get in a hurry to spend money around here.
I also don't see why you don't have the PC heads checked before you make any decision. It's very possible you could run the heads and the pistons with only some machine work.
But if money is flowing there's nothing wrong with AFRs either.
I understand what you mean! But I unloaded those heads to my brother who has plans for them on a little 350 project he has coming up, so that made my decision a little easier. I definitely don't want to spend more than is necessary, but I would like to have this engine done right the first time.
This piston stuff is all new to me and a bit confusing, so that's why I was hoping I could get a recommendation on a good one too go with that would meet my needs and get the CR I'm shooting for.
Caleb
  #77 (permalink)
Old 05-22-2013, 09:46 PM
techinspector1's Avatar
Wiki Edits: 326
You'll need to find out what length rod is in the motor. 5.7" rods used a piston with a ~1.425" compression height piston. 6.0" rods used a ~1.125" compression height piston.
  #78 (permalink)
Old 05-22-2013, 10:04 PM
I believe they are 6.0", but I will verify that ASAP.
Caleb
  #79 (permalink)
Old 05-23-2013, 03:45 PM
They are definitely 6" rods.:thumbup
So, would these fit the bill?
http://www.jepistons.com/Products/140350.aspx
  #80 (permalink)
Old 05-23-2013, 08:09 PM
Wiki Edits: 326
140350 Product Detail Information - JE Pistons
No, those are +7cc's pop-ups, same as you have now.
You will want a -4cc to -7cc piston. I don't know if you want to stay with forged or back off a little to a hypereutectic piston. If I were in charge of spending your money and trying to look for max value for the money , I'd probably choose a forging something like this....They may be a closeout because of the low price. The low price may be because of the ring thickness. Most builders nowadays will opt for the thinner (and therefore lighter) 1/16" rings to help prevent ring flutter at high rpm's. I see nothing wrong with using 5/64" rings in a motor that will be rpm limited to ~6000.
http://www.summitracing.com/parts/pb...make/chevrolet
If you wanted to stay with SRP forged, this might be a choice....
http://www.summitracing.com/parts/sr...make/chevrolet
  #81 (permalink)
Old 05-23-2013, 08:18 PM
I don't know how I screwed that up, I meant to link to the same 138095 flattops that you linked too and not the domes! I will take a look at the others as well, and do more research to see if forged would be worth the money or not.
I noticed those pistons on Summit say +5, while the same part number on SRP's site says -5. What gives here, misprint on Summits side??
Many thanks Tech!
Caleb
  #82 (permalink)
Old 05-23-2013, 08:52 PM
Proud LOSER
Many thanks Tech!
Caleb
No miss print, summit lists their dish as positive
For example if you use their compression calc in the effective dome field a dish will have a + beside it.
The Following User Says Thank You to bygddy For This Useful Post:
Sixshooter45 (05-23-2013)
  #83 (permalink)
Old 05-23-2013, 08:56 PM
Ok I follow now. Thanks for the clarification!
383 stroker - intake oil leak - HELP! transamgta383 Engine 16 08-16-2011 11:52 AM
carb for my 383 stroker casadoctor Engine 11 04-06-2010 10:34 AM
Too much carb on 383 stroker ? y2k600f4 Engine 6 09-07-2009 08:51 PM
carb for my 383 stroker 7fastelc0 Engine 3 09-20-2002 10:22 AM
