please help with my combo
ok so me and my friend are building him a little s-10 project so he can have some fun before he moves back to the uk.
so here are the specs 1970 gm 350 2 bolt main complete rotating assembly ballanced for 8500 rpm edelbrock performer RPM aluminum heads 64cc w/ 2.02/1.60 valves guide plates and screw in studs crane energizer aluminum roller rockers 1.5 edelbrock torker single plane intake speed pro short skirt hyperuetic(?spelling?) pistons rated at 10.74 w/ a 64cc combustion chamber bored 0.030 over chevy pink rods shot peened and re-sized stock crank turned 0.010 comp 3/8 hardened pushrods comp cam dur. 259/266 lift 550/570 edelbrock 750cfm carb proform distributor msd 8.5 wires edelbrock aluminum water pump serpintine belts and short tube headers with open exhaust this is all going into an s-10 that should weigh around 2800 lbs and will be running a 10.5 slick with a built th350 that includes race clutches trans go shift kit and all the other goodies as well as a tcs 2800 rpm stall tourque converter it will have 4.11 posi rear and im jsut wondering what this motor should be revved until and also what the horsepower should roughly be as well as 1/4 mile time?? we roughly based the engine off of the edelbrock 420 hp 355 so im hoping this will make at least that maybe more because of the bigger cam and more compresion- thx alot |
is that an @.050 duration on the cam?
If so its way too much, those heads intake ports are like 170cc. Your stock bottom end will grenade long before you ever get to 8500 RPM... or 6500RPM for that matter. Other than that it looks strong- K |
