Most k cars were pressed in.......This pic is out of a 72 challenger
Chrysler used this type for many years,And I dont know how many diffrent measurements there was.hope this helps ..good luck |
Try Moog K772 ball joint for a Chrysler..Some apps include 65-73 dodge and chrysler and 80 monaco . (that would mean KRUZR's 72 challenger is the same also
I have one of those at the shop that I can measure iffin ya want me to. later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
Kruzer & Mike,Thanks for the replies! Mike I'd like you to check the dimensions if you have time. We've been looking for a lower ball joint, I didn't know they used the upper in both applications.
Thanks again, Fred |
yours ---------------------------mine...
moog K772Lengths; OAL- 4.18" --------------------------------- 4.25 Cup length-1.62" ---------------------------1.595 Taper length-1.44"---------------------------1.4 Thread length-1.12"-------------------------- 1.1 Diameters: Cup @ threads-1.84"---------------------------1.84 Top of taper-.72"----------------(big end) .712 Bottom of taper-.62"------------(small end) .610 Threads-.56" ------------------------------------.56 (9/16-18) As all of the critical measurements are within .010", I'd say you are good to go with that K772. Now, when I said that the uppers and lowers were the same, I was referring to the ones that I have seen installed in the upper AND lower aftermarket tubular arms, from several different mfgrs. That does not mean some company has not done it differently, I have just not seen it. So I will clarify, the MII stock arms do not use screw in type. (I know if I didn't say something about that, in 2 years someone will join the board and ressurect this thread just to call me on that point.) HTH, Mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike; 11-28-2007 at 08:51 AM. |
| Heim End/ ball joint | henny496 | Suspension - Brakes - Steering | 6 | 02-08-2006 04:44 PM |
| Ball Joint spacers | bct | Suspension - Brakes - Steering | 7 | 12-03-2005 12:51 PM |
| Front Ball joint ... PICTURE | bg | Suspension - Brakes - Steering | 17 | 04-16-2005 01:24 AM |
| silly curb | onecoomofo | Suspension - Brakes - Steering | 16 | 12-18-2004 11:36 AM |
| 1996 Bronco Ball joint | wally | Suspension - Brakes - Steering | 3 | 12-02-2004 07:09 PM |
