Please help no oil to the heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2002, 07:28 PM
87 350monteSS's Avatar
Monte Super Slow
Post Please help no oil to the heads
Ok heres the prob i just finished putting a new crank kit in torqured everything right got it all put back in started it up and the first roller tip rocker on the drivers side is getting oil fine through the push rod none of the other pushrods on either side are delivering oil only thing i can think of is when i put on the new intake gasket maybe a piece fell through and clogged a hole ??? any suggestions will help i just wanna drive it
Old 10-14-2002, 07:58 PM
E.T. divided by $ spent= Speed
Post
Did you prime the motor befor you fired it??Did you soak the lifters in oil befor puttin um in??I'd take the distributor back out and prime the motor till all the rockers are getting oil this way your sure you have oil.And watch your presure when your priming it make sure you got good pressure.
Old 10-14-2002, 09:25 PM
4 Jaw Chuck's Avatar
Post
How long have you run it? Did you rev it up a bit after verifying you have oil pressure? If you packed the pump before firing the grease gets into the lifter and needs some heat to melt before you'll get oil to the rocker. As long as you squirt oil on it by can you can run her for a while...as long as you have oil pressure! Give us more info. I always use vaseline for this reason, lubriplate is a big no-no.
And I don't want to hear questions why I have a tub of vaseline in the shop and Pinup girls on the walls! :p Hey, all women know what building cars is...masterbation. <img src="graemlins/spank.gif" border="0" alt="[spank]" />
— Han Solo
Old 10-15-2002, 02:03 AM
New Member
Post
Make sure you have a empty distributer body when you prime, otherwise there is no way oil can reach the lifter oil galleys...
Old 10-15-2002, 02:57 AM
aka Duke of URL
Thumbs up
4 Jaw said;
[quote]I always use vaseline for this reason, lubriplate is a big no-no.<hr></blockquote>
And so is chassis grease...
[quote]And I don't want to hear questions why I have a tub of vaseline in the shop and Pinup girls on the walls!<hr></blockquote>
Oh...If I thought that, I would sneak into your shop at night and put sand in it...
Prelubing a fresh engine before fire is very important. As mentioned, you can use an old distributor base or the primers themselves are not that expensive.
Old 10-15-2002, 05:26 AM
Post
It has been a little raw lately...
— Han Solo
Old 10-15-2002, 06:49 AM
Monte Super Slow
Post
thanx for the help
[ October 18, 2002: Message edited by: 87 350monteSS ]</p>
Old 10-15-2002, 07:51 AM
aka Duke of URL
Unhappy
[quote]Oh...If I thought that, I would sneak into your shop at night and put sand in it...<hr></blockquote>
[quote]Originally posted by 4 Jaw Chuck:
<strong>It has been a little raw lately... </strong><hr></blockquote>
That's nothing...My wife has always said sex with me was boring. I thought nothing of it until recently when she cut me off fully. I had to take matters into hand. My hand fell asleep!
Now I know what she was talking about. And after all the years I thought she was losing conscience while I was making love to her...sob...
