Please Help, Problem with TH350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2005, 09:21 PM
Hi guys my dad and I are currently restoring a 66 Chevy II SS. My dad has rebuilt the 350 trans and we have a weird problem with it. When the car is up on jackstands the trans does not leak a drop through all gears, but when the car is on the ground it wants to force fluid out the dipstick tube. My dad has checked the vents and they seem to be open. Please let me know what you think could be causing this problem. Thanks and take care
Old 06-19-2005, 10:06 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
If you are restoring the car , it did not come from GM with a t-350 tranny. I am not sure how you are restoring the car, so I mention that.
next, You mention checking the vents. There is only one vent on the t-350 tranny. Near the top of the main case where it starts to curve up to form the bell hosuing area over the converter. It is just off center to the passenger side
Regarding the on & off the ground checks........ Do you mean that you are driving the car when off the stands or sitting and idling? The tranny will get warmer during actual driving than on jack stands.
Do you have a extra/add-on tranny cooler on it? Trans cooler in the radiator only?
Do you have a higher stall speed converter?
Old 06-20-2005, 08:45 AM
Yes, I am driving the car on the ground. The car has the trans cooler in radiator only. I have a slight stall converter in it, not sure of rpm but it is mild. Thanks
Old 06-20-2005, 02:34 PM
Last journal entry: PICTURE TEST
fluid
In my own personal experience the only thing i have seen push fluid back out the top of the tube is way over filling, or a blocked vent.... I am not saying there are not other causes but it's just what i have seen....
You said he checked the vent... How did he do that????? As far as i know the th-350 is the only trans where you can get the pump to case gasket in backwards and everything in the trans will work but it will block the vent tube. Ask me how i know???? I have done it... Everything worked perfect in the trans but it would push fluid out the fill tube.
I would be looking real close at the vent first....
keith
help with 5.0 306 install problem scuba1 Engine 9 03-20-2004 04:52 PM
406 pre ignition problem 406 ss monte Engine 20 02-29-2004 12:31 PM
th350 speedometer problem john69 Transmission - Rearend 4 06-17-2003 07:38 PM
th350 problem..... oldcarguy85 Transmission - Rearend 2 04-24-2002 05:06 PM
stumbling on acceleration problem 67SS350 Transmission - Rearend 1 02-06-2002 07:03 PM
