Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Please help with some upholstery questions
Old 01-03-2013, 10:19 PM
Bodnar720 Bodnar720 is offline
pretty much I dont know a lot about older machines, as I use a new Consew and Adler. Alot of trimmers feel that it is easier to use a single needle machine due to making compound curves on double needle machine is a complete pain in the As*. single needle will never bee as straight as dual but can be damn close, dependant on the trimmers skill set
Attached is a needle guide for leather that was made available By greg at Keystone sewing in philly, great guy!! should remedy the same on alacantara.
I was curious if you had ever had a seat in alacantara before, simply because a bit different, not a huge fan of it and that stuff is anything but cheap.
Keystone bros has a similar material known as street suede, and personally, 12 bucks a yard sounds great compared to 70 bucks a yard lol.
File Type: pdf Groz-Beckert_Needles_for_the_processing_of_leather.pdf (1.26 MB, 280 views)
The Following User Says Thank You to Bodnar720 For This Useful Post:
brmax (08-05-2013)
