Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - please help timing a ZZ383
Old 01-21-2005, 11:52 AM
Tech @ BG Tech @ BG is offline
Technical Support Barry Grant
Timing Pointer
Another option would be to get one of the pointer bases that bolts to the distributor, that has a base bolted to the intake. Since the "actual number" doesn't make a difference and you're just looking for the best performance you can use that as an easy way to change higher or lower.
