Please help. What is this thing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2009, 10:47 PM
I had disassembled my 351W motor, and now I'm putting it all back together. I just don't know what this washer-like part is and what it does. Please give the name and the purpose. Much appreciated. This part went on the crankshaft nose.
Old 09-07-2009, 10:50 PM
powerrodsmike's Avatar
Wiki Edits: 161
Oil slinger, Pitches oil up on the timing chain and fuel pump cam..
Later, mikey
BE different....ACT normal.
Old 09-07-2009, 11:17 PM
RSM's Avatar
RSM RSM is offline
looks a little bent too
Old 09-07-2009, 11:37 PM
sqzbox's Avatar
My pipes are my music
You didn't tell him where it goes!
Old 09-07-2009, 11:50 PM
ericnova72's Avatar
More for Less Racer
Goes on the crank nose after the timing gear but before the balancer.
Old 09-08-2009, 10:17 AM
Don't leave it out, without it the front crank seal won't!
Bogie
Old 09-08-2009, 10:57 AM
302 Z28's Avatar
Bogie
No sh**, ask me how I found that out many years ago.
Vince
Old 09-08-2009, 04:38 PM
woodz428's Avatar
Troll Hunter
Originally Posted by ericnova72
Goes on the crank nose after the timing gear but "before the balancer".
and the timing cover too.
Old 09-08-2009, 04:46 PM
OLNOLAN's Avatar
Don't Feel Like The Lone Ranger
Vince
LOL,Me too,289 ford.
olnolan
Old 09-08-2009, 07:16 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I'm guilty to back many moons ago, And once is all it took. ,,,,,,,,,,,,,,,,,,,Cole
Old 09-09-2009, 08:33 AM
I'm not seeing how it does that. Does the disk curvature gather leaking oil? Is it the front cover gasket that prevent oil leaks?
Old 09-09-2009, 03:42 PM
OLNOLAN's Avatar
Oil Deflector Ring
Hey Bud, Slip it on the crank, pushed against the crank sprocket,cup facing out. Install timing cover, install harmonic balancer, when the balancer bolt is tightened up, the balancer holds it in place against the sprocket. It's purpose is to deflect the deludge of slinging oil away from the timing cover seal to keep the seal from leaking. Without it the seal will leak. That's about the best I can explain it. If you already put it together without the deflector, take it back apart, get new gaskets and put it back together. You can carefully straighten that bend out with some pliers. I forgot to put one back in a long time ago, found it in the bottom of the part washer along with a 3/8 bolt. I pulled it apart put the deflector in(I do believe I bent it too,trying to pry it off,it was stuck on from Quaker State sludge) never did figure out where the 3/8 bolt went.LOL olnolan
What the heck is this thing for? Jmark Engine 15 07-14-2009 09:09 AM
The #1 Thing YOU Can Do to Improve the Lounge Jon Hotrodders' Lounge 58 09-28-2004 07:11 PM
Is metal in the oil filter a bad thing? :( TurboS10 Engine 26 09-11-2004 08:33 PM
Sanded to bare metal...What's the best thing to cover again? Rocket1 Body - Exterior 7 09-09-2004 05:24 PM
Who would ride this thing? Malibucdl Hotrodders' Lounge 25 12-22-2003 11:25 AM
