Please identify these kingpins or axle set up - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2008, 12:53 PM
I don't have a clue as to what these are, can't find any listings with these sizes, but the kingpins are 3/4" round and 5 3/8" long, heres a couple of pics if that helps. I need to find the parts so I can put it back together, thanks in advance, Mark.
ID:	34277   Click image for larger version
ID:	34278   Click image for larger version
ID:	34279   Click image for larger version
Old 11-18-2008, 01:51 PM
Frisco's Avatar
Glad To Be Here
Looks like mid fifties (1954) GMC or Chevy truck as to the axle setup. Spindles also appear to be from the same or possibly Chevy passenger car spindles.
A question for the solid axle, king pin, early ford spindle kind of guys... Centerline Suspension - Brakes - Steering 11 02-17-2008 03:57 PM
Rear Axle Leak Ford 9 inch zonk Transmission - Rearend 5 08-19-2005 06:30 PM
Axle Tube Number ID Help Morex52 Transmission - Rearend 2 01-08-2005 08:00 PM
setting roller rockers Thacolbster Engine 2 02-07-2003 06:48 PM
9" Ford (Bad gear set from Summit?) mcbroom Transmission - Rearend 4 02-07-2002 03:23 PM
