Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pls critique my combo...need input
  #26 (permalink)
Old 07-29-2012, 05:35 PM
123pugsy's Avatar
123pugsy 123pugsy is online now
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Originally Posted by bygddy View Post
The hell with it, I'm gonna hit the snap on truck at work tommorow and see what bits they have and take a run at it, at this point I have zero money in the heads anyways, should I be sending them to the machine shop before I try this of after? And when blocking off the heat passage on my intake can I simply use thin aluminum Ala: pop can? I figured I would just cut to the proper shape and use that spray gasket sticky stuff to hold it in place until its bolted down?
Dave
No pop can material. It will be gone quick.
I believe most intake gasket sets have the block off plates included. I haven't had any luck with them though as they burned right thru.
