pls help with my engine... - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2003, 08:43 AM
first.... sorry for my bad english....
i have a engine with the number 3970010.
3970010 is a 302 or 327 or 350 engine.
i have found the following numbers.
K12 05 CMJ
16B49 5806
is this a 302 or 350 engine ?
thx
Old 09-08-2003, 09:50 AM
Silver_Camaro's Avatar
Superior Wheels Quality Tech
is it the original motor in the car? if so what year is it?
Old 09-08-2003, 10:03 AM
WBrianS's Avatar
New Member
Waldi,
Here's a link:
http://www.mortec.com/castnum.htm
according to this page, if you're sure it's from the mid-70's then it's a 350. GM used this casting nubmer pretty regularly and on a variety of block types.
I've got a 350, 4-bolt with that number. Good block, high nickel and little changes for smog.
-B.
Old 09-08-2003, 02:51 PM
camaro, thats not the original engine.
i dont understand this....
k12 05 CMJ
CMJ =
1974 CMJ 350 t4OO police - 4 full size
1980 CMJ 305 automatic trans. H - - full size/Camaro
but
16B495806
1=chevy
6= year
b= plant
why a 6 ? 6 is for year 76 ?
but the CMJ code says 74 or 80
this is the engine...
http://stadt.heim.at/entenhausen/120001/olds/1.htm
Old 09-08-2003, 03:16 PM
MI2600's Avatar
Member# 3287
Waldi,
My reference book shows the CMJ is listed to a 350 from 1974 to 1976. It also lists the 1980 305. I would say you have the 350 which would correspond to the 16B**** number you listed for 1976.
Keep trying your English and we'll keep trying to help.
Old 07-25-2006, 09:50 AM
BK455's Avatar
CMJ 350 engine benefits?
I did a search on this police engine in this forum and found alot of trouble shooting posts. I would like to know what is the positive characteristics of this engine compared to the other 350's. I just picked one up and was told that it is rebuilt. Came completely dressed out and only cost 600.00. I need to know if they are special in any way, or just because they were used in police cars has made them popular.
Thanx,
Dennis
Nibornej@cox.net
Old 07-25-2006, 09:57 AM
These blocks are good because of the high nickle and or tin content in them, makes them stronger. Waldi, if your block is a 4 bolt main its a 302 or 350. Since your numbers(16B and CJM) correspond to a 350 from the mid 70's thats my vote. Very good block for a build IMO.
Old 07-25-2006, 10:14 AM
BK455's Avatar
CMJ 350 vs. 305
I would guess the only way to tell the difference between these two engines is to go into mortec and pull the casting numbers. The 305 shows a different casting number, but can still have the cmj stamped on front pad.
Old 07-25-2006, 10:17 AM
305 would be a 2 bolt main block, the 350 would be a 4 bolt. Also you could measure the bore which should be 4" for a 350 and 3.736" for the 305.
