plug on 350 trans driver side
have a 350 im guessing a turbo transmission. heres my question, is there a lock up plug that i need to reconnect so my transmission will work right? see when im driving and i get up to third gear its not running like it has overdrive so when i let off the gas it starts switching down gears like a manual transmission. is it the lock up switch?
The trans will work normally in every respect w/o the TCC lock up operational- w/the exception of a slightly higher torque converter stall speed. I'm not sure I completely understand your symptoms, you might try explaining the problems you're having one more time. |
305 trans plug
well im not real sure but my truck will switch all gears but as soon as i let of the gas it starts slowing down real fast switching gears down. is that normal if my lock up is not hooked up? see i had a 82 chevy i pulled this engine from and put in a 75 chevy but i didnt see a lock up on the 75 so i left it unplugged.needless to say i didnt even get the harness because i thought it was a speedometer wire.
| Need Help FAST!!!!!!!!!! | millertime85 | Engine | 14 | 06-25-2008 07:01 PM |
| 350 trans problem | impala metro | Transmission - Rearend | 2 | 03-19-2008 07:39 PM |
| How Does This Stuff Work? | docvette | Electrical | 3 | 06-18-2006 03:00 AM |
| What heads for a 350 have the spark plug wires on top? | batman09 | Engine | 13 | 09-25-2004 10:52 AM |
| 350 4x4 trans to 700R4 2x4 trans swap??? | punk1c5040 | Transmission - Rearend | 1 | 02-01-2004 11:14 AM |
