Plug Gap - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2012, 06:38 PM
Plug Gap
327 with measured 11.5:1 static CR. Dynamic ratio 8.75:1 with 254 dur cam. cranking pressures around 230-240 psig. Pertronix trigger firing Pertronix 45 kv .6 ohm coil. 8.5 mm MSD spiral wrapped wires, MSD 6AL ignition control. NGK plugs. Currently gapped at .045. Should I leave it there or open them to .050?
Old 08-08-2012, 07:42 PM
farmwalker's Avatar
What kind of heads do you have?? Stock? afermarket?? If so what brand?
Old 08-08-2012, 10:30 PM
68NovaSS's Avatar
Wiki Edits: 9
What do you mean by "measured" c.r. 11.5:1?? How did you measure it?
Old 08-09-2012, 05:41 AM
ProFiler aluminum angle plug. 195cc ported to 203cc. heart shaped 64cc chambers
Old 08-09-2012, 05:44 AM
I verified (measured) all parameters used to calculate SCR, like chamber volume and deck clearance, which is blueprinted. Calculated the SCR using all verified numbers.
Old 08-09-2012, 05:48 AM
MSD does better with a smaller gap. I have a similiar setup, but with a small shot of nitrous, and I run TR6's gapped at 35 and works best for me.
Old 08-09-2012, 06:18 AM
Richiehd's Avatar
JS-70
45 KV coil, I wouldn't go more than .045.
Old 08-09-2012, 08:34 PM
farmwalker's Avatar
I would contact the company that makes your heads, they would know what the gap should be. I once thought that I should go to a .45 gap but was way better with a .35 gap. My plugs would foul and with headers, it takes for ever to fix. So to make sure, you head company will know.
plug gap jipice Hotrodding Basics 2 09-06-2011 02:18 PM
plug gap fishead # 1 Engine 2 10-04-2010 09:39 AM
What plug gap? FastOrange Engine 8 08-14-2010 12:41 AM
could this be because of the plug gap? 53LEDSLED Engine 4 01-29-2005 03:19 PM
plug gap dubie Engine 5 06-28-2004 12:57 PM
