plug gap - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2004, 08:30 AM
dubie's Avatar
Last journal entry: the goods
plug gap
What is the ideal gap to run on a 350 with an HEI
Old 06-28-2004, 09:30 AM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
.035-.040 thou. You can get more gap if you run a hot coil. Step it up to .050 or .060. Longer arc= better burn... if your coil can push it!
K
Old 06-28-2004, 12:08 PM
Last journal entry: PICTURE TEST
GAPS
There is not a set answer for this question. It's as important to get the correct heat range of plug for your set-up. then you will need to play with the gaps some to see what is the best for your engine. Don't be suprised if the engine works better with a smaller gap.
Keith
Old 06-28-2004, 12:25 PM
Wiki Edits: 3
I didn't think heat range and gap had much to do with eachother... am I mistaken? I thought heat range is just how much unsulator you have coming up the bottom of the electrode...
K
Old 06-28-2004, 12:31 PM
yep
killer your right, gap and heat range have nothing to do with each other. I might have worded my reply wrong.
I should have said the correct heat plug will gain more benifits then changing the gap. But when you find the correct heat range changing the gap may or may not gain results.
Keith
Old 06-28-2004, 12:57 PM
Wiki Edits: 3
righto, i agree-
K
