Plug gap - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2004, 07:11 PM
dzguy's Avatar
Plug gap
Does any one know what the proper plug gap is for a 1969 302 chevy. It is a dz motor. Thanks
Old 09-19-2004, 07:19 PM
poncho62's Avatar
Wiki Edits: 5
.035..........
Ontario Rodders
Old 09-19-2004, 10:22 PM
GoneNova/406's Avatar
.035 with the 69 ignition.if you use msd or something equivalent it will increase to .045 or even .060.if you have the 69 stock ignition and like free h.p. cut your ground strap back on the plug end.its worth 10 h.p. and works.you will have to replace the plug more often but they're cheap.
www.edelbrock.com/automotive/sparkplugs.html
check out "cut back ground electrode,jc4 type."
Old 09-19-2004, 10:29 PM
poncho62's Avatar
Wiki Edits: 5
If it was worth 10 hp, don't you think that the plug makers would make them that way?
Ontario Rodders
