plug on heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2013, 09:52 PM
plug on heads
can anyone tell how too remove the plug on the side of head i am having a hell of a time need too install a heat sensor, is there a special socket i can buy to remove?
Old 02-08-2013, 10:21 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It's likely an 11/32" square drive. Snap On and others sell them (shown below), or you can make one from a 1/2" drive to 3/8" drive adapter by grinding the 3/8" end down to fit the pipe plug.
I've always used a torch to heat the cast iron around the plug before removing, but you might get yours out w/o heat.
Old 02-08-2013, 10:54 PM
wow my plug does not look like that, its on a elderbock head its square head that sticks out
SBC Heads (straight plug) Cristianss427 Engine 12 10-28-2012 11:15 PM
summit angle plug heads Nelson67Camino Engine 3 03-20-2009 07:21 PM
Why straight plug heads and angle plug heads 406chevelle Engine 6 03-19-2006 01:36 PM
angle plug heads and s-10 mychevystang Engine 7 03-21-2005 03:37 AM
Will Angle Plug Heads Work? strikingthematch Engine 5 10-27-2004 07:10 PM
