Plug wire ends - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2009, 01:42 PM
Plug wire ends
Does anyone have an easy way to put 90 degree ends on plug wires that is easy. Is there a lubricant, some magic or any suggestions would be appreciated. Thanks.
Old 10-10-2009, 01:49 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
I have used silicone spray in the past, but a little WD40 does much better when installing the boots. Just squirt a little bit in the boot, and push it on.
Old 10-10-2009, 03:57 PM
I use reg greese just a dab. they are tight i just bought some new 8mm wires man what a ***** getting them in i trimmed off the very end. they seem to have a little bit of taper. someday some guy will invent a heat shrink system for spark plugs.
Old 10-10-2009, 09:01 PM
sqzbox's Avatar
My pipes are my music
Liquid dish soap off the kitchen sink works real good. That is, if sliding the plug boot over the plug connector is what your talking about.
Belden wire used to recommend it on their cut to fit HP plug wires.
Old 10-11-2009, 12:19 AM
JeffB's Avatar
Plug wire ends
Run the wire thru the boot first, then crimp on the terminal,then spray Armorall in the boot and on the wire and pull it back thru you can use a flat tip punch for leverage, K-Y Jelly works good too!
Old 10-11-2009, 05:18 AM
sqzbox's Avatar
[QUOTE= K-Y Jelly works good too! [/QUOTE]
No surprise coming from a ford man!!
Old 10-11-2009, 05:51 AM
da34guy's Avatar
All suggestions sound good, but IMHO dielectric grease is the best and proper way.
What's the proper way to wire an alternator? 70bird Electrical 18 08-14-2010 12:24 PM
Plug wire holder question. HemmiGremmie Engine 1 03-07-2006 10:05 AM
Spark Plug wire looms and Ram Horn exhaust mainfolds Jag Daddy Engine 6 07-19-2005 09:13 PM
spark plug wire lengths robman909090 Engine 8 05-12-2004 10:07 AM
How do these spark plug wire Ohm checks look? crazie Electrical 2 03-15-2004 06:20 PM
