Plug wire question? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2006, 03:34 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Plug wire question?
Hello.
Im going to run a set of Taylor 8mm plug wires on my gremmie. With the shorty headers n straight plug design, should I use straight, 45 or 90 degree plugs? Tnx, Hg
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 03-17-2006, 06:00 PM
Last journal entry: frame build
Use a combination of terminals. Which one where is determined by which one keeps the wires furtherest from the pipes.
Old 03-17-2006, 07:01 PM
302 Z28's Avatar
I have a set of 90 degree MSD 8MM wires on my SBC with shorty block hugger headers and they work fine. I also have a set of GM Performance parts 8MM wires with 135 degree ends that I am going to have to put on Ebay .
Vince
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Cool *********** Rodrunner Hotrodders' Lounge 3 09-12-2011 03:02 PM
Spark Plug Wire shortage??? TheBreeze Electrical 10 11-04-2005 05:01 PM
Plug Wire Arcing riesman20 Engine 4 07-11-2004 12:00 PM
spark plug wire help needed 68GEETEE General Rodding Tech 6 06-04-2004 05:43 AM
