Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Plug Wire resistance.
Old 03-02-2012, 05:25 PM
1971BB427's Avatar
1971BB427 1971BB427 is offline
Always check your meter for zero before you start testing anything. Need to set it on x1 setting and hold the leads together. If it is more than .3 to .5 ohms it's got a problem with the leads. If the leads are going bad, then don't use it for batteries either, or you'll get low readings there too.
