-   -   Plug Wire Suggestions (http://www.hotrodders.com/forum/plug-wire-suggestions-225213.html)
JParker77 10-20-2012 05:01 PM
Anyone have any input on plug wire selection? I am currently using Mallory 8mm, but they are in need of replacement and I'm not sure how much value there is going from a $40 set to a $90 set. I'm running a 302 with TF aluminum heads, a fat cam and Mallory HP no point ignition setup.
Thanks!
Oldguy48 10-20-2012 05:09 PM
I ended up with a set of Moroso wires. Previously, I tried using a set of AutoZone wires, then a set of Bosch wires (both supposedly good quality). Both were junk. Got a set of Morosos, and have had no problem at all.
WDCreech 10-20-2012 09:03 PM
I used to use Moroso wires, but with upgrading the spark box for Racing, I started getting crossfire. Went with Taylor "409" wire on both engines and haven't had a problem since. If you walk around the pits, at a drag strip, you'l find most of the serious racers use Taylor.
Bill
vinniekq2 10-20-2012 09:05 PM
Aurora wires are very good
S10 Racer 10-20-2012 09:19 PM
1 Attachment(s)
We use Taylor wires on our sprint cars, no problems yet. But we run a mag and not a distributor.
