plug wires
I`m running a HEI with a pertronix flame thrower coil and module, summit spiral core wires. before I bought the coil and module about a year ago, I was having problems with stock ones, they never lasted long before the spark would turn yellow, indicating it was weak, I`ve noticed lately my car hasn`t no where the power it should, so I did a ignition test, again, the spark is yellow, I can open the tester to about a half inch, it`ll arc the distance, and the color is yellow with a light blue, if I close the gap to around .050 the spark is yellow, I checked the plug wires, and resistance is fairly high, so i`m asking can bad wires cause the spark to be weak? I`m hoping the coil and module haven`t went bad already, the wires are about a year and a half old, they don`t have a lot of miles on them, maybe about 4000 total, the car has no high RPM misses or skips, but it uses a heck of a lot of gas and has little power. I know the summit wires are somewhat cheap, but I thought them being spiral core, they would last longer than this. any info is welcomed and appreciated.
