Plug Wires, Cross arc-ing?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2004, 08:25 PM
arch's Avatar
My bike has 4wheel disc brakes
Friend has a V6 with a distributorless ignition system (coil pack). The engine has been knocking at higher rpms. We've been all over the place trying to find the problem. Tonight, we noticed that EVERY spark plug wire is arcing to the engine/intake/or another wire close to it. While watching two wires in the dark with the engine running, you can see bright blue glow between the entire length of wires when they are 1cm or less apart. So we changed wires, 4 times, from 3 different places. Set on there now are the dealership recomended wires bought from the dealer. I've never seen brand new wires arc like this. Right though the shielding, nothing is exposed. Whats goin on?? Anybody ever seen this before?
Old 10-05-2004, 09:06 PM
DoubleVision's Avatar
Yes, this has been a problem for many years and usually, spiral core spark plug wires eliminate the problem. But it`s still important to route them correctly in order to keep them far enough apart to help keep it under control.
Old 10-05-2004, 10:17 PM
arch's Avatar
Really... hmm... cant believe I've never heard about it before... or maybe i have and im just not remembering...
Problem is, only way to route the wires is right next to each other. about 1-2cm apart
Old 10-05-2004, 10:38 PM
Jmark's Avatar
I wonder if its normal for them to do that? Like the magnetic fields causing a slight glow from the wires that really doesn't cause any misfiring. The only way they can cross fire is if you have a break or porousity in the shielding on the cables. Hard to believe that you've tried 4 sets and all of them are bad. Maybe your miss is caused by something else and not the wires.
My wifes previous Buick 3.8 had the wires routed bundled together under the big plastic engine cover and we never had any problems, and that thing put out some serious voltage!
Old 10-05-2004, 10:47 PM
Replace the leads they probably have damaged insulation also check and regap the spark plugs, to large a gap can cause the coil voltage to go high enough to increase the chance of spark jump
Old 10-05-2004, 11:47 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
It's a common problem when the wires are to close together and you have something causing a resistance, such as bad plugs or the wrong gap.
Troy
If you don't make mistakes. your not doing anything.
69 SS/RS full custom Camaro 98 ISCA Grand Champion
69 SS/RS BB Camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 SS Chevelle BB conv.fresh frame off
26 T sedan street rod
Old 10-06-2004, 06:01 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
I had 3 sets of accell 300+ wires in less than 2 years go bad, plus foul the plugs by jumping spark from all over each wire.
I now have mallorys for a year without any problem.
Its not the setup, just junk wires.
my $200. worth of bad wire of opinion.
Luv the smell of NITRO in the morning.
Old 10-06-2004, 09:03 AM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
Oh I've seen them arc! 1BAD told me how to wait till its dark and mist some water over the wires.
Damned supersucker accel wires looked like 4th of july under there.
Super 40 morosos now, thing *'s and gets.
K
Old 10-06-2004, 08:50 PM
arch's Avatar
huh...
Alright, well, I'll go see him tomorrow and take out the plugs check em out and re-gap them and see what happens then...
Never really seen new wires arc without some kind of break in the insulation... Learning something everyday.
Old 10-07-2004, 08:14 AM
Is there a bad earth wire (grounding wire ),,.
Old 10-07-2004, 10:00 AM
arch's Avatar
Theres a grounding strap that goes directly to one of the bolts for the coil pack. Its been checked and rechecked... seems fine.
