Plugged hole in sbc block - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2012, 06:54 PM
Just wondering if someone could tell me what the threaded hole on the passenged side of my 350 sbc is/was for. It's located near the center and pretty much directly behind the collector of my block hubber header. Does that hole go all the way though? Thanks!
Old 08-22-2012, 07:16 PM
BOBCRMAN@aol.com's Avatar
Centered, just above the oil pan is a drain hole. Yes it goes thru into coolant. Takes a pipe plug or knock sensor.
Old 08-22-2012, 07:44 PM
Thanks Bob!
Hole in the engine block- What to do? TWCarpentry Engine 10 07-27-2011 10:15 AM
SBC heater hoses plugged Eric64 Engine 3 02-01-2011 04:44 PM
Stripped out hole in aluminum block Raidrbabe27 Engine 2 01-09-2007 06:12 PM
400 SBC Steam Holes - Plugged Koolaid Engine 16 09-14-2006 10:00 AM
SBC - block dipstick hole? Limey Simon Engine 3 01-30-2003 02:13 AM
