Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - plugged vacuum modulator T-400
Old 10-21-2012, 07:23 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Was there a valve in the hole under the modulator?
Does this trans shift from 1-2 when the shifter is moved from 1-2? Same with 2-3? Does it stay in the gear that is indicated on the shifter?
