Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - plugged vacuum modulator T-400
Old 10-21-2012, 08:16 PM
0trbo4myCHEVUICK 0trbo4myCHEVUICK is offline
Originally Posted by BOBCRMAN@aol.com View Post
Was there a valve in the hole under the modulator?
Does this trans shift from 1-2 when the shifter is moved from 1-2? Same with 2-3? Does it stay in the gear that is indicated on the shifter?
I do not know if there was a valve in the hole under the modulator but I will take it off and look as soon as I get home from work.
No, the 400 does not shift at all when the stick is moved to 1 or 2. I put it in drive, it engages, and I take off fine. Problem is, I take off all the way to 4k and no shift.
