Plugging holes in 32 frame rails - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2007, 05:29 PM
Last journal entry: Bringing home the 401 Nailhead
Below is a pic of the driver side 32 Ford frame rail. Previous owner did a spectacular job of mounting a steering box. Just burned holes in frame rail. Naturally I am going to plug these up. My question is what do you guys do with the factory holes like the ones for the stock steering box? Do you also fill them or do you leave them for authenticity?
Name:	frame holes.jpg
Old 01-23-2007, 05:56 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Are you building an authentic hot rod? I have never seen one of those. Build it like YOU want it to be!
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 01-23-2007, 07:40 PM
Hotrods are what you make em there are no rules there are no guidlines but if it were me i'd leave em i didnt touch a single hole on either of my model a rails mostly cuz it added to the look i wanted. Rods are personal though do what makes ya happy
Old 01-23-2007, 11:26 PM
We used a steel plate inside the rail where the steering box mounted on the 32 3W Coupe we're finishing up. Tacked the plate inside and welded up the holes from the outside. Did make a plug for the steering sector hole(the big one) and welded around it. Easier than cutting and welding individual plugs in all the holes. Weld 'em up, grind 'em smooth...done.
Old 01-24-2007, 01:46 PM
I agree ... but be careful not to warp the rails ... I always box my original 32 Ford frame rails ... install the plate from the back to cover the holes ... and then box the rail. Then plug the large hole and then weld up and grind the smaller holes ...
Old 01-25-2007, 08:00 AM
Irelands child's Avatar
You have some steel that has been intergranularly affected by very high cutting torch heat and you will first have to enlarge the holes somewhat to move closer to the original unaffected base steel. Clean up the holes with a file and a large drill bit. Then you can use a uni-bit if they need to be even a bit larger. Make up plugs that are a tap-in fit and weld in place, preferably with TIG, or if not available, a MIG. A stick welder will put heat back in the same area that has already seen too much. For safety's sake, then full length box the frame - it is 75 years old and probable has lots of stress areas and microscopic cracks from the crappy roads in the thirties and early forties.
Dave
Irelands child
36 ford truck on a 32 frame? eromasik General Rodding Tech 2 12-15-2005 03:33 PM
Replacing camaro rear frame rails 72camaro Body - Exterior 6 05-28-2003 04:54 PM
Best Bedliner ... Frame Rails ... Toneau Cover? horvath Body - Exterior 5 04-20-2003 06:50 AM
Nova Frame Motor Mounts........ bg Engine 0 01-05-2003 03:17 PM
28 on duece rails ? doowopsinger Body - Exterior 0 02-17-2002 08:33 AM
