Yup..bad idea..if the oil overheats it basically cooks the oil resulting in sludge and poor lubrication..then the engine has a premature failure..that oil cooler is there for a reason so I woudl fix it..Even tho it is cold out the underhood and interior engine temps can get to a damaging level..
Sam
The oil cooler on those trucks was part of a towing package... Also noticed your in Canada (COLD...! ), I dont think its going to hurt also seeing how many many of those trucks dont have it also...
But just go to a GM dealer and get the new little plastic seals and replace them since your going to the trouble of removing them to plug the lines... Last edited by Bumpstick; 02-04-2007 at 07:15 AM. |
The filter adapter has a built in bypass so you could pound the lines flat I suppose.
Or get another filter adaper that doesnt hook up to cooling lines. Your truck is probably set up for heavy duty use (such as pulling a trailer) at least for a light duty truck, so factory gave you a little extra insurance like engine oil cooler. But zillions of small blocks never came with oil coolers so I wouldnt sweat it. |
re: Plugging oil cooling lines a bad idea?
Yep, as has been said, not a good idea. But on the other hand, a bypass of some type would probably be fine for the winter.
Get a non-EOC filter adapter and swap them out until you're ready to fix the lines. Any 4.3, 305 or 350 of the same vintage should be a good donor. Should be able to get one for pocket change at the local wrecking yard since it's not something they sell many of, like none. Your's on the other hand is a pricey item so don't lose it.
BINGO unless there is going to be a lot of at max capacity hauling/towing. get rid of em and move on. |
| Synthetic Motor Oil In 454 Rebuild | leejoy | Engine | 36 | 11-20-2006 02:34 PM |
| Oil Filter relocation kit... | jmbjs | Engine | 4 | 04-11-2006 08:15 AM |
| M.S. requested joke thread | hotrodit | Off-Topic | 186 | 12-20-2005 12:26 PM |
| 1988 chevy s-10 blazer, and i want to put a 327 in it. comments, good idea bad idea. | 1969css | Introduce Yourself | 1 | 12-22-2004 05:18 AM |
| A little humor | Kevin45 | Hotrodders' Lounge | 8 | 10-21-2004 12:47 PM |
