plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2010, 01:01 PM
plugs
what do you all think rich lean about right seams to me like they didnt last long before i was getting miss fires only about 12K miles
Old 07-22-2010, 03:09 PM
Picture is quite fuzzy, but I see a lot of orange on the outer shell and the insulator. This would make me think this engine is in a very wet environment on the outside, like a boat, or a vehicle close to the water, a swamp buggy for instance. I also see a lot of orange on the insulator, assuming this isn't from some chemical or colorant in the fuel, I suspect there's coolant leaking into the cylinder from somewhere.
Bogie
Old 07-22-2010, 03:36 PM
sqzbox's Avatar
My pipes are my music
Rtyauch301, Are you using octane booster? I've seen that color before on my 455 I tore down after a rod bearing spun. I let the dam thing over rev one time and I broke the top ring on 4 pistons. I used octane booster in it about 2 out of three tank fulls and when I tore it down the reddish orange deposit was on everything, valves, piston tops, chamber, and plugs.
12,000 miles really isn't that bad on an engine you know, that's about 1 years worth of driving. I would just replace the plugs and chock it up to maintenance!.
From your pic and user name I assume you have those plugs in a 301 cu. in?
What induction system do you have?
Ignition?
Mileage on the motor?
Old 07-22-2010, 03:50 PM
It's a 400 ci pontiac factory intake 2 bbl 117k no booster I don't think that stuff helps
Old 07-22-2010, 04:04 PM
Also I wouldn't say I live on a wet area... I live about 3mi from tn river in northern al
Old 07-22-2010, 04:08 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Do you use only one brand and grade of fuel? If it's an "off brand" premium, this can be due to the additives.
Old 07-22-2010, 04:20 PM
I do allways get my fuel from the same station it's a texico allways 93 oct
Old 07-22-2010, 04:26 PM
sqzbox's Avatar
Change the plugs, run some WOT passes, pull a couple out and take some more pic's and show us what you find and we'll go from there.
Old 07-22-2010, 04:28 PM
sqzbox's Avatar
I forgot,. What kind of oil do you use?
Old 07-22-2010, 04:35 PM
Gtx 20W 50
Old 07-22-2010, 05:51 PM
Thought I would add it seems to have solved my mis at idle but after the car warm up at wot I get a miss or maybe predet I'm not sure which..... Car run at around 180 to 190 never gets any hotter I'm thinking I might have a carb issue here it's never been rebuilt that I know of and iv had the car for about 40k miles so I bought a rebuild kit today befor work figured I couldn't go wrong for $18...... Also I will do a few wot runs on the way home and take a photo of the plugs when I get home.... One more thing I don't burn oil and iv never lost any water I do loose about half a quart of oil ever 3k but I beleave all that goes out the rear main seal as it does leak
Old 07-22-2010, 06:06 PM
sqzbox's Avatar
1 qt. every 3K is pretty good for a 100K+ 400! I'd look into solving the plug issue before ripping into more than 1 thing at a time. Let's look at the plugs first.
Your plug's in the pic look to be R45TS AC's or equivalent, right?
Old 07-22-2010, 09:43 PM
theirs about 25 miles on this plug and about 4 wot runs to 90 excuse the paper towel it was hot looked new to me aside from a little white powdering which i tried to get in the photo with my crappy camera.. so were to from here.. also if anyone knows how to shrink this image it looks clearer smaller... also the old plugs were #86 autolite coppers and the new ones are the same
Old 07-22-2010, 10:02 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Might be a little clearer...
Old 07-23-2010, 07:05 AM
sqzbox's Avatar
Plug looks consistent with a 117K mile carbed engine.
What kind of ignition system do you have? It might be getting a little weak.
That might explain some of the deposits on the plug already.
Need to change the air filter and PCV valve. When you change the PVC valve, pull the hose from it to the vacuum source and clean it out also.
If your still using the stock air cleaner, you need to change the little filter element inside the cleaner that filters the crank case.
Before you jump on the carb, I would check the ignition first. Inspect the inside of the cap for light or dark carbon tracks between the contacts and build=up of deposits. worn and dirty rotor button. Check the cables and make sure their not touching any exhaust or rubbing anything metal including the oil dipstick tube. Pay attn. to #5 and #7 cables that could cross fire between them. You can check the wires also at night. Any cross firring can be spotted
by a small spark between the cables. Move the cables around with a wood dowel or something like that to keep from ZAPPING your finger!
Check all this and if it's good or replacing worn part's doesn't improve the slight miss, then start on the carb.
Carb issue? (Long) mrevil Engine 13 03-30-2009 05:55 PM
DO THEY MAKE "CYLINDER HEAD BRASS FREEZE PLUGS ? SCHOONER Engine 12 02-05-2009 07:28 PM
Blower Motor - Timing - Spark Plugs: Need Clarification Please 41willys Engine 19 08-31-2008 10:01 AM
Cam Bearings and Core Plugs (SBC 350)89 gandl2123 Engine 15 03-26-2007 03:06 AM
Rant: Bosch Plugs Cost me $300.00 Rolm Engine 7 07-22-2004 09:50 PM
