Plugs for vortec heads? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2010, 06:55 PM
I am building a 355 Vortec motor. I have a new set of plugs for the older style 350, which the block is. They are Bosch plugs, can I use them in Vortec heads?
Old 10-24-2010, 07:03 PM
Last journal entry: It Will Work
They won't work. You need the spark plugs for the vortec heads.
Old 10-24-2010, 10:04 PM
406cu.in. of tire smokin' fun
Last journal entry: 406 Build Thread
AC Delco R44LTS (or equivalent) I believe is the plug you want.
Old 10-25-2010, 01:51 AM
F-BIRD'88's Avatar
Yada Yada Yada
In the Chevy OEM L-31 vortec heads (062-906 castings)
You want to use a Champion RS12YC for normal street duty and a Champion RS9YC for hard racing or moderate nitrous. Gap at .035"
Old 10-25-2010, 08:48 AM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
yes the R44LTS fit the L31 vortecs and are what i run,,,
Fbird are there advantages to using the champions vs the delco's, or is it a just a matter of preference, curious
also how do the R44LTS and RS12YC heat ranges compare?
Old 10-25-2010, 05:38 PM
Ok, thanks for the info, I had a set of Bosch for the older style and my buddy needed some for older and had vortec ones, what an awesome coincidence. Anyways I now have the Bosch Platinum Plus, are these pretty good performing plugs?
Old 10-25-2010, 11:35 PM
FastOrange's Avatar
Older plugs dont work in vortec heads, they thread in, but not far enough.
I would stay away from the champion's, i bought them , Regapped for my HEI (.045) and truck wouldn't run right.
Bought a set of NGK TR55's (Favorite among Fullsize Truck Forum guys) regapped, and my problems went away.
Also, just dont buy a set and leave the factory gap it is .060 (Unless you want this gap)
Old 10-25-2010, 11:57 PM
F-BIRD'88's Avatar
Yada Yada Yada
if you ever get a new spark plug that mysteriously does not work right check very closely for a cracked or separated-loose-mis bonded porcelain.
Then check with a OHM meter. Very easy to break the resistor inside.
If that new spark plug got dropped somehow it is now trashed.
If /when you are re-gapping a spark plug that has a factory .060" gap, to a smaller .035" gap you may have to trim-shorten the ground strap length. The end of the ground strap should not go past the center electrode. Even or slightly shorter is best.
These are the two most common cause of new spark plug troubles reguardless of brand name.
Dropping the spark plug box almost guaranties most all the plugs in the box or shipping case will be trash.
New spark plugs have a warranty. If you get a new set that are damaged or .... return them to where you bought them for free replacement.
In 35 years I have never had a problem with Champion brand spark plugs.
AC Delco work fine too.
Old 10-26-2010, 12:29 AM
F-BIRD'88's Avatar
Yada Yada Yada
Like this................
Old 10-26-2010, 11:25 PM
FastOrange's Avatar
Thanks for the Info F-Bird!, didn't realize that.
milling heads Raufus Engine 15 02-22-2010 02:41 PM
Why spend money on heads? F-1Rodder Engine 8 03-07-2008 12:09 AM
Shorty Spark Plugs for Vortec Heads?? acr Engine 1 05-13-2005 09:23 PM
looking for some head(s) now i'm gonna explode! bullheimer General Rodding Tech 25 04-12-2004 01:16 PM
Heads novatech Engine 10 01-17-2004 01:27 PM
