plugs wet with oil??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2005, 05:18 PM
the plugs in my SBC are all wet with oil. Where can it be coming from? Past the rings, down the valve stems, or??
Old 12-15-2005, 05:24 PM
Wiki Edits: 31
ither 1, are you getting blue smoke out the tailpipe?
Old 12-15-2005, 10:06 PM
97Z28's Avatar
NTI Grad.
it could be either one... do a compression test or a leakdown test to see if one of the rings are broken or worn. is it all of the plugs? or just 1 or what? freshly rebuilt engine or an older one?
Old 12-16-2005, 08:49 AM
Blue smoke on starting only. All plugs are wet. Engine was rebuilt just a few hundred miles ago, but the heads and valvetrain were not touched...how would I check for leakage down the valve stems?
Old 12-16-2005, 09:45 AM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
its the valve stems. Depends how much you care about solving the problem, more than likely little or no oil is actually getting consumed in your 3000 mile intervals. As long as your valves are sealing ok at teh seat (i.e. a decent compression test) you should be ok. Just get to it when you can.
K
Oil Pressure questions RObs71Nova Engine 22 05-02-2009 01:45 AM
It's alive...finally AngliaBob Engine 5 02-19-2005 12:46 AM
Windage trays....... onebadmerc Engine 70 01-04-2005 06:57 AM
No oil pressure cleancut Engine 12 04-30-2004 10:35 AM
Tip of the day on oil additives that you need to read mcgyver-ky Engine 10 04-19-2003 05:17 AM
