Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Plumbing Compressor....
Old 12-02-2005, 05:06 PM
Rob Keller's Avatar
Rob Keller Rob Keller is offline
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
might be best to not get any to close to the end of the pipe like a thread or two.
use the same principle with Teflon tape leave it back a thread or two and you will never get any loose tape clogging up a valve ,check valve or a screen
pipe dope will weep a little when it gets warm(i think)
good luck
SR66
I'm not prejudice, I hate everyone
"SlowRide66"
"Illegitimis non carborundum"
