Plumbing Compressor.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2005, 09:48 PM
I'm in the process of plumbing my new compressor, I got 3/4 galvanized pipe. I'm using T Plus 2 teflon sealent on the threads I was wondering if this stuff is going to screw up my water seperator/paint hose?
Old 12-02-2005, 06:06 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
might be best to not get any to close to the end of the pipe like a thread or two.
use the same principle with Teflon tape leave it back a thread or two and you will never get any loose tape clogging up a valve ,check valve or a screen
pipe dope will weep a little when it gets warm(i think)
good luck
SR66
I'm not prejudice, I hate everyone
"SlowRide66"
"Illegitimis non carborundum"
Old 12-07-2005, 09:25 AM
Off hand, I think not. Since the line will be pressurized, I don't see how anything could migrate in. I'd also try to keep the sealant away from the begining of the threads and only on the threads that are going to be engaged.
Old 12-07-2005, 10:17 AM
70Shorty's Avatar
Bob
tape it
For a air line,, I'd just use the tape, keep it back from the end a thread or so and you'll be good to go. It's only air for pete's sake,,,
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
air lines CARGUY Garage - Tools 96 11-16-2006 05:11 PM
Compressor plumbing??? Pepsimayn Body - Exterior 7 10-27-2004 12:40 AM
