Plumbing a coolant surge tank - need help
The top of my cross flow radiator w/cap (20lbs) sits below the level of intake manifold. The fill point is an additional cap (16 lbs) that is mounted directly over the thermostat on the intake manifold. I have been told that the pressure from the water pump can actually push coolant out of the cap at the fill point which seems to be the case. The solution suggested is to install a regular neck for the thermostat and a surge tank higher than the engine. I have identified a location and the hose from the bottom of the surge tank to the inlet side of water pump will be no problem. I have a question about the "bleed" line to the highest point of low pressure side of radiator. Before I have a bung soldered in can I use a cap from a pressure testing kit and plumb the "bleed" line to the top?
What kind of car/engine is this? I just can't visualize it.
If you install a surge tank and connect the hose from the bottom of the surge tank to the bung at the radiator fill cap, which is the overflow outlet, then install a new style radiator cap on the radiator the overflow bottle will feed into the radiator when the engine cools down. That will top off the radiator.
The additional step is when doing the intial fill to warm the engine up to operating temp with the radiator cap off. When the thermostat opens have someone rev the engine up to around 2000 RPM and fill the radiator to the top. Then install the cap and lower the RPM. That will insure a full fill. Fill the surge tank half full and you are done. |
Fine for a conventional setup but my setup has the radiator well below the level of the engine. My fill cap is on the intake directly above the thermostat. When the thermostat is open and the cap is off the coolant is forced straight up and not into the radiator. |
Here is a link explaining radiator cap location. http://www.stewartcomponents.com/tec...ech_Tips_2.htm |
Basically the surge tank I want to install is a remote fill. I just wandered if I can plumb the "bleed line" through the top of a pressure test cap rather than pull the whole system to have a bung soldered into the rad. Guess I will just try it and see. Will post the results when I get back into town. |
look at any 63-67 corvette, thats how the factory solved the same problem, plumb yours the same way. while the pressure tester cap thingie would work i think eleminateing the cap and soldering a bung on top is a far better solution.
The way a radiator cap works is that it allows water out into the overflow tube when the pressure in the radiator reached its rated pressure (water expands when it gets hot BUT the pressure keeps the water from boiling) it then allows water to bleed out of the system. then after the motor cools down the water contracts back, causing a vacuum and a small valve in the radiator cap allows the water to be sucked of the overflow tank back into the radiator. This is why the overflow is ported to the BOTTOM of the tank.
I have never seen a water pump that would push a 16lb cap up, most of the time you could hold the pressure back with your hand. Remember water is not compressible. So if there is a restriction in the system THAT bad it would be sucking the bottom hose closed. Also its easy to have 8-12 lbs on the system at 160*, so 200* could easily have 16 depending on the system. Get a tank off of a small GM car that has a PRESSURIZED over flow tank and route a 3/4" heater hose from the top of the intake to it and then back into the input of the water pump. The cap on the tank will hold 16lbs and if you have a problem with the cap on the radiator you could have it brazed up. |
| Custom Air Compressor Guide | goleafsgo_12 | Garage - Tools | 13 | 03-13-2012 02:10 AM |
| overflowing coolant. | TVR383 | Engine | 8 | 09-12-2006 02:18 PM |
| Whats the correct temperature my 350 should be running at? | batman09 | Engine | 101 | 10-23-2005 12:29 PM |
| Gas Tank Plumbing Follow-Up | Doc68 | Engine | 0 | 01-11-2004 07:28 PM |
| Fuel Tank Installation Plumbing Questions | Doc68 | Engine | 9 | 01-05-2004 06:20 PM |
