plumbing in hard lines for a compressor - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 01-03-2010, 05:52 PM
Originally Posted by smithkustoms
According to the sharpe diagram it says you need a flexible hose between the compressor and pipe system. Where in the world do you buy a 1"+ flexible leader hose able to handle 150psi and the heat of the compressor?
Tractor Supply, Northern tool or Surplus Center will have hydraulic hose, just order the size and length you need with pipe thread ends and you will have a hose that is cheap, easy to install, rated for an excess of well over 1000 lbs and will last forever! Probably more than one place locally that will make them for you too, the local Orilley auto parts makes them here.
  #32 (permalink)
Old 01-03-2010, 08:38 PM
Was reading through another forum everyone is familiar with and came across
this.
Not that I would try what he did with used compressors, but it seems it would work well with new, out of the box tanks.
  #33 (permalink)
Old 01-03-2010, 08:50 PM
Ratdoggy's Avatar
Hammer torch chisel...
Last journal entry: Getting there
I am going to use copper tubing to run from compressor to the air drier. Then to a hose reel. Probably about 40 feet or so. I can never seem to get pipe threads to seal in the orientation I need them to be. I'm more comfortable soldering copper. Does the type and size of tubing matter?
  #34 (permalink)
Old 01-07-2010, 11:09 PM
I run a siphon, pressurized and large bead blaster with this setup, no air dryers or dessicant canisters, just pipe.
http://www.1969supersport.com/draw1.html
Rob
  #35 (permalink)
Old 01-08-2010, 06:48 AM
Ratdoggy's Avatar
The diagram shows a filter, is that only for painting?
BTW I've seen your diagram before and was VERY impressed by your web site
  #36 (permalink)
Old 01-08-2010, 09:11 AM
I paint and sandblast and wash my vehicles in the paint room.
Rob
air lines CARGUY Garage - Tools 96 11-16-2006 05:11 PM
Plumbing hard lines, I need clips MM in NM Suspension - Brakes - Steering 12 01-07-2006 08:58 PM
Hard piping air lines ... help (LONG) candygram Garage - Tools 19 10-18-2005 07:23 PM
How flexible do cooling lines need to be? McDeuce Transmission - Rearend 3 03-22-2004 01:36 PM
Brake lines for conversion kit??? ChevyLuv Suspension - Brakes - Steering 9 09-26-2002 09:36 AM
