Plumbing hard lines, I need clips - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2006, 02:51 PM
I have my benders, flaring tools, unions, other hardware and have made my first few brake and transmission cooler lines. Not bad,, I think this may work. For days I've been looking for clips to route these lines. The factory uses little all metal clips and I found some nylon clips at a local hardware store but they are all the wrong size plus I don't like Nylon...
Does anyone here know of any supplier who can get me A: the right sizes and B good sturdy metal clips to make a nice neat job of this?
Somebody has to make these things...
Name:	Brake line clamps.jpg
Old 01-05-2006, 02:56 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Been a while since I was in NM but I do recall there are some industrial suppliers in Albuquerque that may have those..Check the yellow pages..
OMT
Old 01-05-2006, 03:29 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
If not, call the Denver Specialty Center @303-399-0677-they've got 'em-
Craig
Old 01-05-2006, 03:51 PM
37ford4dr's Avatar
bobs77vet
Last journal entry: frame repair
do you have lowes around you? they stock them inthe nuts and bolts aisle
Old 01-05-2006, 05:03 PM
I've seen them in Home Depot's, around the electrical section, where cable ties and miscellaneous electrical hardware is. Summit or Jeg's would also have them.
Old 01-05-2006, 05:36 PM
what tubing are you bending? i can't find a decent bender to bend stainless tubing, 1/2"
Old 01-05-2006, 05:45 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I buy clips like those at Lowe's Home Improvement Center.
Old 01-05-2006, 05:52 PM
Rigid #408 tubing bender..
It WILL do the job.....
Old 01-05-2006, 07:25 PM
www.mcmaster.com
If they don't have it...you don't need it.
Old 01-06-2006, 01:05 PM
BIGSKY's Avatar
See project in Photo Album
I used similiar clips for my brake, fuel and air lines. I got them in packages of 8 or so at my local Napa Auto Parts, a stocking item.
Old 01-06-2006, 09:43 PM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
Summit has them in all sizes. Also, the exact package you show in the picture is available at Sears Hardware stores, 2 to a bag. Summit's are cheaper and come about 6-12 in a bag depending on size.
Old 01-07-2006, 02:30 AM
Info about Adel clamps: http://www.aeroelectric.com/articles/adel.html
Old 01-07-2006, 08:58 PM
Thanks, what I needed was "Adel" clamps. I did a search and found the exact sizes that I needed to make a neat job.
I've been using regular steel line, 3/16" and 5/16", that I have found easy to double flare and easy to bend/route for this first timer. Can't see the need for stainless and the pain it is to work with. I got all the stuff I needed (except the Adel Clamps) from a guy in Bradford PA that goes by "Performance Tools".
As I said, I've found the plumbing project easy so far with the application of some common sense. I just hope when it's all together it won't leak all over the place. That'll be the real test.
Name:	Torino brake plumbing stuff.jpg
ID:	9019   Click image for larger version
Name:	Torino  LF suspension.jpg
TH-350 Cooling Lines Flaring leejoy Transmission - Rearend 2 01-02-2006 09:53 PM
Questions about stainless steel brake lines ckucia Suspension - Brakes - Steering 14 06-13-2005 08:26 AM
Front clips and frame swaps --- More work, less value Centerline Suspension - Brakes - Steering 23 05-25-2005 09:42 PM
Kerry and jobs overseas... lluciano77 Hotrodders' Lounge 9 12-25-2004 09:59 PM
Brake lines for conversion kit??? ChevyLuv Suspension - Brakes - Steering 9 09-26-2002 09:36 AM
